Super 44 sound clips
Discussion in 'Technical' started by scooper77515, Jun 19, 2007.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    soundin SWEET:bowdown:
  2. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Sounds good.
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    'Sounds darn good, and a little bit similar to mine...
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Sounds great Scott! Wow, those fuel pumps are obnoxiously loud, I have one also.
  5. scooper77515
    Once I get jute in that fender, and put the backseat armrest panels back in, much of that fuel pump sound should disappear. More so when I jute the trunk.
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    Scott, my pump was that loud while I was doing my interior also. I juted the back and the area behind the sidepanels in the rear. I am thinking of installing a light to tell me my pump is on, it is that quiet now.
  7. scooper77515
    Good to hear that...where is your pump mounted and how (oops, just jacked my own thread:p )
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    Under the trunk. It is mounted on rubber mounts and fastened through the bulkhead that the fuel tank sits in.
  9. Rando76
    Rando76 Member
    Claremore, OK
    Sounds great! I know all about fuel pump noise - I have the same problem on my '73. :16suspect
  10. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    That is mean sounding...fuel pump. The mufflers ain't bad either.:rolleyes: (y)
  11. scooper77515
    Silenced the fuel pump...
    I took my fabric car cover and shoved it in the space between the outer rear quarter panel and the trunk...that triangular shaped hole on the side of the trunk floor. Can't hear the pump now.
    Just figured you would like a quick fix for quieting those down.
    Also, installed the exhaust professionally and have new sound clips at http://mmb.maverick.to/showthread.php?t=34454&highlight=Super
