#1 |
Member
Truck Top-loader O.K. for Maverick?
Hello,
I have come across a top-loader for sale in my area for dirt cheap. The dude selling claims he bought an 1984 F-250 with 60,000 miles on it for the engine, and is selling the tranny. As far as I can tell it is a top-loader. It's a 4-speed with entry plate on top and a side mounted shifter. It was mated to a 300 I-6. Will this fit into a 1976 maverick currently fitted with a 3-speed? Will i be able to convert to floor-shifted still? I am planning on installing a 302. The guy says the bellhousing won't fit because the starter is in a different location, but the bolt pattern is the same. Can I Gerry-rig it together? Will a truck gear ratio be appropriate for such a small car? I want a lot of off the line torque, will I need to replace my rear diff. as well? Please help, I am very confused! Thanks, Jack |
| Sponsored Links |
#2 |
I'm mister heat mizer...
If that trans is out of an F-250,first gear is going to be a granny and useless in a car.As far as the starter location is concerned you may be able to relocate the starter to the side the new trans requires if there are no clearance issues(I think there will be)Clutch linkage comes to mind.It should mount to a regular 302 std shift bell housing if it isnt an integral BH/trans set up.Fish around in the search section here for tranny swaps.You will find answers to most if not all or your questions.Good luck.
#3 |
Remember
That transmission should be a 3 speed overdrive. 3 + 1 OD. Maybe not.
It should work the same as any top loader 4 speed. Although the shifter may not be in a primo location. If I am reading the post correctly this transmission is from an inline 6 cylinder Ford. Granada's also had this type top loader 3 speed OD transmission.
__________________
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming-----WOW---Whata ride!!!" |
#4 |
Isaac Serna
I read somewhere that the granada od trannys were more alike to the real toploaders than the truck ones.
http://www.5speeds.com/toploader.html this is the site I was refering to. |
#5 |
Member
I don't know that any truck came with a tranny that will be suited to a car, but you describe something close...
You can unbolt your tranny from the bellhousing, leaving all that hooked to the engine/car, and slide the tranny right out. Then, if this is truely a 3+1 toploader, it will slide right back into the bell pretty as you please. You will just have to get a car friendly shifter, the truck shifter may not fit. The 3+1 toploader has all the exact same gear ratios as your current 3 speed. The only difference is that it has an OD stacked on top of the 3 gears. You may or may not like that idea. If you like the gear spread of your 3 speed now, and can appreciate the economy of having another gear, then it's all good. If you are wanting the 4 speed in order to bring your gears closer together, which is the more common want, then this tranny will not do the trick. For street driving, the wide ratio toploader is the best option. It has the same top and bottom gears as the 3 speed, but has the 3 speed's second gear split into 2 gears. The 3+1 should be looked at as an "ultra wide" toploader. The close ratio has all the gear ratios close together and is not as street friendly. All depends on what outcome you want. 3+1 is great for fuel economy.
__________________
A redneck's last words: "Hey ya'll, watch this!" |
#6 |
truckdrivintrailertrash
And the 250/300 use the same starter and location.
__________________
#7 |
Member extrordiare
Vehicle(s): 1966 Mustang, 1972, 73, 73 and 73 MavericksiTrader: 6 (100%)
If it is a toploader with a side mount shifter then it will work fine in either car. If it was made for that year vehicle then it is most likely a four speed over-drive transmission. They are essentially a three speed with an overdrive gear built in. If you have the rear gears for it it should work well. Just remember that it is not as strong as a Ford Top loader. YOu can, I believe, put the "Toploader" gearset in it and make it a toploader but you will lose the over-drive function. The shifter is mounted just a bit further back than the toploader but the real give away is the bulge in the passenger side of the gearbox for the over-drive. The true Toploader has no bulge in the side of the case.
__________________
Paul 1 each 72 2dr., 73 2dr., 73 4dr., 66 Mustang Coupe. |
#8 | |
Member
Hold on it is a F250
Quote:
Many of the truck transmissions are very very heavy to take the load requried and they have a large amount of mass and weight if you look at the height of a NP435 in comparison to a T5 there is a several inches on the 435 and about an 80 pound difference between the two even though the T5 is a 5 speed and the 435 is a 4 speed. you would have better luck looking here http://www.car-part.com for a T5 or T56 out of a mustang in your area you can probably find one cheaper, give you a better gear ratio then the transmission in the F250 and give you alot less hastle installing it plus it is a 5 speed. Well thats my worth.
#9 |
Member extrordiare
Markso125,
The same toploading four speed was used in cars and trucks. TOPLOADER IMPOSTERS: In 1977 and 1978 there was a late model 3 speed overdrive transmission made for intermediate passenger cars, light duty pickup trucks and vans. This transmission looks just like an early Toploader but is not a performance transmission at all.The tag numbers are: RUG BP; RUG CA; RUG CL; and RUG CD. The casting numbers on the main case or tail-housing start with D7DR for 1977 model. Some of the main cases have an ORION cast on the drivers side. The gear teeth are cut very thin and the ratios are almost the same as an early 3 speed with .85 or so overdrive in 4th. At first glance it looks just like the original Toploader. Many more Toploaders were transplanted into pickups to get rid of the granny gear top loaders with top mount shift towers. All of the side mount shifter top loading trannies will fit in cars and trucks with the appropriate shifter.
__________________
#10 | |
Member
Quote:
It is like trying to find a clark 5 speed out of a 1969 International school bus for your truck 98% of the time you are going to run into the most common transmissions out there. I am not disagreeing that they were not in the trucks and they were not in them that year but what is the probability of it? It would be a more feasable option to find a T5, a T56 or something else along that line. |
Interested in this thread? Receive email updates and post your own response by registering today, it's free! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Top loader to T5 | jpollard | Technical | 7 | 2008-12-29 00:04 |
| top loader | stevelonie | Transmissions | 10 | 2007-03-03 08:23 |
| top loader | stevelonie | Transmissions | 0 | 2007-02-11 23:59 |
| 2 top loader 4-speeds | wardf | Maverick/Comet Cars/Parts For Sale | 2 | 2004-09-07 00:34 |
| ford 4 spd top loader | 171grabber | General Maverick/Comet | 2 | 2003-08-26 13:09 |
