Bumper tuck
Discussion in 'Technical' started by Bob Wiken, Sep 27, 2008.
  1. Bob Wiken
    Fayetteville, Arkansas
    After reading the threadabout bumper tucks yesterday, I decided it was a good thing to do.
    I decided to err on the safe side and only went 2 1/2 inches instead of the 3" that some spoke of. So far, it's not too complicated. Just do a lot of measuring and MARK THE OUT SIDE OF THE FRONT PLATE. That's so yopu can locate the front plate when you weld it back on.
  2. Bubba Bob
    Bubba Bob Member
    Auburn, AL
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    measure once cut 3 times :D
  4. Bob Wiken
    Here is the pic you so much deserve
    LOL
  5. Bob Wiken
    I measured from the plate back 2 1/2 inches from each corner.
    then connected the dots.
    I used a 4" grinder to cut what I could reach and then used a Sawzall to finish the cut.
    Grinf both the end and the plate smooth and carefuylly weld back together.
    De-Grease and paint.
    Ready for install
  6. Bob Wiken
    It took about an hour in all for one side.
  7. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I need to do this one day. Post up the finished pictures when you are done. I wonder if 2 1/2" will be enough to not block the side marker.
  8. Bob Wiken
    I am hoping 2 1/2" won't block the light or I'll have to shave it. Or find anmother set of bumper mounts and go back to stock
  9. 71gold
    i cut 3 !/2"...
    matches the stock rear bumper to light...
    ...:Handshake...
    " big bumper slide "
  10. Bob Wiken
    htey are just lights on the side of thefenders. See the pics
    Mine is a '73
    I have front and rear lights
  11. 71gold
    Bob...Bob...Bob...:slap:
  12. Bob Wiken
    LOL
    I'm off to do the other side and I'll get a pic of how it looks in a while
  13. rthomas771
    Have you any thoughts/plans on lighten up the inside shell on the front bumper? I'm thinking about cutting the center section out and use the ends to bolt the bumper to the bracket. The idea also came to mind to make my own brackets out of 2 pieces of channel iron. I hope this will loose about 45 lbs of the total weight. For you small bumper guys wondering...a big bumper with inner shell and mounts weights 89 pounds on the bathroom scales!! Thats a lot of extra weight to tote around if you think about it. The chrome shell by its self is 29 lbs
  14. Bob Wiken
    Here are pics,. Everything is just snugged up to see approximate fit. No adjustments have been made to REALLY even things up. I think it will look good when finished
  15. 302mav76
    302mav76 Isaac Serna
    Monterrey, Nuevo Leon, Mexico
    '76 Maverick
    That's great, I've always wanted to see a '73 with the bumper tucked in. Keep the pictures coming!
