8.8 from a mustang in my maverick?
Discussion in 'Technical' started by random hero, Jan 22, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    i have a mustang just waiting to be stripped, i want to put the rear from the mustang into my maverick, would it be too wide? i have the pony wheels which look to have a deep backspace, but i'm not 100% sure. how much wider is the mustang rear than the maverick. my mustang is an 88 with a 5.0. also, if i brought both rears to a machine shop they should be able to switch the mounts for my leaf springs from the 8 to the 8.8, or atleast put new ones on the 8.8
  2. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    the 8.8 is one inch wider per side than the stock rear. you can buy a new set of spring mounts for $20 with the 8.8 rear the pony's will fit on your car on the rear but the front if you have the 4lug front the bolt pattern is wrong4.5 vs4.25
    brad:)
  3. Joe Dirt
    I bought spring perches at the local northern tool for 3.99 each 3" axle tube
  4. random hero
    hudson valley
    1972 maverick
    yea, it's just temporary until i do a 5 lug conversion...(5 lug disc rear 5 lug dis front...hopefully mustang 2 ifs)
  5. Bryant
    you will need to either change the flange on the pinion to a yoke or put driveshaft flange on the mav drive shaft and probly have to shorten it. you can get a yoke off a early 80s f150 or bronco that will work on the 8.8 mustang
  6. random hero
    hudson valley
    1972 maverick
    i have the mustang driveshaft...i have a full mustang for parts (body and frame are shot) could i use the driveshaft from the mustang? or is it to long?
  7. Thack
    Thack vision advicator
    Moreno Valley Ca
    We have an 8.8 in Tammy's and I have the 79-93 mustang Ford Racing Alum drive shaft in it. We do have a T-5 but I'm pretty sure it will fit the auto. the length of the shaft is 45.5
  8. safado
    safado Member
    West Phoenix, AZ
    love the search function.. was looking to see if the fox 4 lug would fit the older ford 4 lug..= fail .. thank you bradleyGt
  9. baddad457
    The pinion flange will work as is. Nothing to change there.
  10. baddad457
    The Stang driveshaft is close to being the correct length, you can figure that out after the rearend swap. I'm running a stock length 98-04 Mustang driveshaft on my Comet (45.5") with the C-4 and 9" rear with a long 1330 yoke.
  11. safado
    safado Member
    West Phoenix, AZ
    Is there a write up on the fox 8.8 in a mav/comet? I see bradleyGt has done it... anymore info? I guess the mustang one is better than the explorer on since the center section is centered on the stang.. the explorers though are 31 spline right.. noting you can't swap over later..
  12. baddad457
    It's a bit harder to go 31 spline in a Stang 8.8 due to the smaller bearings on the ends of the axle housing. That does make it a good time to change the ends to a 9" style and get rid of the C-clips though.
  13. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    I have a chance to buy a 8.8 rear end out of a fox body mustang..it is rebuilt with new disc brakes..will it fit my 73 maverick with proper backs
    spacing wheels??
  14. Bryant
    it wont just bolt in. the fox 8.8 uses a 4 link suspension. you have to cut off the controle arm mounts and weld on leafspring pads. i belive that the fox diff is wider than a mavericks diff, so you will need a deeper offset wheel to fit into the wheel well.
  15. Mavaholic
