Well it's been awhile but I finally was able to get the clutch pedal into my car, now I need to get the firewall adjuster in, I have the MustangSteve kit... I am trying to get the Firewall Adjuster/Support in and am having issues with clearancing the master cylinder and the rubber gromet from the fuse block... It would be really helpful if I could get some picture of their adjusters/supports. thank you.
i didnt go with that setup because of that very reason. i cant recall anyone else using it in a maverick...
My car doesn't have the blue topside adjuster, just remembered. I have one, just didn't use it. I'll get the pics anywho, and get them to you tomorrow.
Here is a a pic pf mine....hope it helps http://mmb.maverick.to/attachment.php?attachmentid=33441&d=1240417068
That looks like the one I have from mustang steve... did you have to grind/drill or modify the block any to make it work? thank you.
I got mine wedged in there but it's jammed between the mc and the rubber gromet for the wires coming from the firewall, and if I was to bolt it in I probably wouldn't be able to remove the mc cap... was there anything else you did that you can remember? the only thing I can think of would be to grind the brace down abit on one side but I really don't want to. thank you.
Yes, we had to grind on it a bit to make it fit in there without a bind. It is still plenty solid and so far I have had no trouble with anything on the install.
I assume you ground the angled cornor that passes over/behind the master cylinder? or was there somewhere else that needed to be modified? thank you
Well it turns out that I did have to trim the front edge right around the threaded hole that is closest to the master cylinder which is where I had the most contact... now I need to elongate the cable whole making it a little higher so the cable doesn't drag on the firewall... thanks for the info
