Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2009-07-21, 15:25   #1
1moregear
Member
1moregear's Avatar
Vehicle(s): 74 and 76 maverick
Images: 9
rack and pinion steering
Has anyone installed a RRS rack and pinion kit? Installing the rack looks pretty straight forward it`s the cutting of the steering column that looks a little involved. Thanks for any input.
1moregear is offline   Reply With Quote
Sponsored Links
Old 2009-07-22, 20:41   #2
jayman
Member
Vehicle(s): 69.5 Maverick/72 Grabber
Images: 15
I have installed them in Mustangs and a Falcon. Just follow the directions, measure everything, then do it again. After that double check your measurements, then if all three measurements are the same and you are sure you read all the directions, and understood them, then it's okay to make the cuts. 8-)
__________________
--Jay
jayman is offline   Reply With Quote
Old 2009-07-23, 08:07   #3
MavMark
Mega Modifier
MavMark's Avatar
Vehicle(s): 1972 Grabber, 351w,EFI,A/C, RRS Rack, Power Everything :)
Images: 1
I installed one this past winter. I would agree, cutting the column is the most involved part of the installation, although I had already taken my column apart to combine it with a '77 Thunderbird column so I could have tilt. Once you cut the bottom of the column, installing the bearing is pretty easy. I had the motor out while I did the install, and all-in-all it was pretty easy.
__________________
~Mark S.
'72 Grabber, 351w, Power RRS Rack,4 wheel discs w/Hydroboost ,A/C, C-4, EFI
http://www.maverickcomet.com
MavMark is offline   Reply With Quote
Old 2009-07-23, 09:37   #4
jncastell
Member
jncastell's Avatar
Vehicle(s): 1974 Maverick Grabber Clone
Images: 21
All you guys out there Rock!!! With your guts to continually improve cutting and welding our near 40 year old cars, even though there seem to be plentiful parts cars in some of your areas. I counted a total of 3 already butchered in our local oldies junkyard, the turbo Pinto cruising wagon looked to be salvageable, so I took some new pics without the snow he wants $900.00.
__________________
John
jncastell is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
