running new trans lines
Discussion in 'General Maverick/Comet' started by HOMERMAV, Oct 18, 2009.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    anybody have any pics of how the auto trans lines were run in a v-8 maverick.my car was a 3 speed car but i put a c-4 in it and need to run trans lines.i bought new 5/16 steel line that i will bend myself but need to know how to route them.
    thanks
    john
  2. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    well i guess since there is no response that im on my own on this one so i will do the best i can.hopfully it will all work out good.i think it will with some careful studying.
  3. blugene
    If it will help, I think the port at the front of the trans is the outlet side. You should have bends at the front of the motor (the lines) that will allow for the engine movement. Alot of us have rubber lines connecting the radiator to the lines. Allows the movement and makes it easier to connect. Careful around the belts/pulleys. Post pics of what you done.
  4. Dave B
    I couldn't help, because I spent the day drinking beer and mixing cement. Plus I used braided steel hose for mine. :)
  5. MikeG747
    MikeG747 Member
    Arkansas
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Mine are out, so I can't be much help. I can tell you my lines were only attached at the ends. :huh: I expected some supporting clips along the lines attached to something.
    Don't think it matters which way the lines are attached to the trans or cooler in the radiator.
    I found a couple of pictures that show a bit of the lines. They were obviously intended to show other things ...
  7. Craig Selvey
    Hope this helps some:
  8. MikeG747
    MikeG747 Member
    Arkansas
    :bowdown: :bowdown: :bowdown:
  9. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    John
    I ran my lines along the starter side of the engine .
    Get a GOOD quality bender and double flaring tool take your time and think about it BEFORE you bend it you will be fine . It may be easier IF you have the engine and trans on the floor if take your time ..
    Good luck Jay
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    :bowdown::bowdown::bowdown::bowdown::bowdown::bowdown:
    You know Craig, the bottom side of your car is cleaner than my living room . . . and I'm a clean freak! :hmmm:
  11. Jeff S
    Jeff S Member
    NoVA
    none
    Are the C-4 lines the same between an I6 and a V8? Im assuming with a bigger engine theyd be run different...but if not I can take detailed pics of mine since I have the whole front end of mine torn apart right now.
  12. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Line are the same size v8 or I6
  13. Jeff S
    Jeff S Member
    NoVA
    none
    After running back and forth to the garage about 10 times snappin pics, I finally found 5 good ones, I dont know where the lines run once they get to the trans, but I did color code them in case some of these other guys know.
    Hope this helps.
    EDIT: After looking at the first pic...I know now where my trans is throwing tranny fluid on the exhaust ....lol
  14. blugene
    Jeff, in the first pic it almost looks like your driver front tire is seperated.
  15. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    thanks everyone this helps tremedously and jeff s and craig and any one else who posted pics thanks i really appreciate it.you to gene almost forgot about you
    john
    now i have to get busy because that is the only thing stopping me from starting the mav.
