Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2002-06-30, 00:02   #1
roadrage
Roadrage
Vehicle(s): 72 Mercury Cougar
Lightbulb Hood Scoop
seems like ive seen this before. since ive got my waterpump fixed and the car is running like a champ again, im thinking that the car is worthy of some cosmetic improvements.
i would say it needs a paint job. we were going to paint the high spot of the hood flat black, but now im thinking... why not addeth a hood scoop before doing so?
i was thinking about getting that generic ford hoodscoop that you saw on so many 68-70 mustangs and torinos.
but if memory serves me correctly.. someone says that it cannot be made functional, unless you located it at the very front of the hood. sounds dumb to me, and i know that would look even dumber.
i know ive seen these scoops on mavericks, and they look good. but i cant honestly say i know if they are functional or not.
i wouldnt bother adding it, if it isnt functional.
anyone got any thoughts on the subject?
thanks
rr
roadrage is offline   Reply With Quote
Sponsored Links
Old 2002-06-30, 01:10   #2
jeremy
I build t5's
jeremy's Avatar
Vehicle(s): 1972 2 door 302 maverick, 1986 5.0 stang gt convertible,66 mustang coupe, HEMI ram
just my .02, but I think the grabber hood looks pretty sharp. I have never been a fan of cutting any body parts for the reason of adding something cosmetic. You take the chance of looking cheesy. What are you looking for, some kind of Ram air? If you are creative enough, you can make anything work. Has anyone ever hollowed out the scoops on the grabber hood here and turned them into functional ram-air?I always thought that would be cool.
__________________
Jeremy
-1972 302 2 dr mav..finally installed: 5.0 crate motor/gt40 aluminum heads/isky roller cam/weiand stealth/holley combo for now, efi in the future/LENTECH AOD
-1966 Mustang coupe 5.0 ford racing crate motor, gt40 aluminum heads, b cam, duraspark elec ignit, t5 with pro 5.0 shifter, 8.8 coming soon
-1966 coupe virgin body but bare roller at the moment
jeremy is offline   Reply With Quote
Old 2002-06-30, 04:50   #3
Mavaholic
Growing older but not up!
Mavaholic's Avatar
Vehicle(s): Original 72 Sprint Owner, 71 Comet GT, 69.5 Mav convertible project, 57 Ranchwagon
Images: 20
I personally like the Mustang/Torino scoop on a stock hood over the Grabber hood. I used to have a Grabber hood on this car but took it off in favor of this set up. I put one of these on my Sprint when it was only 6 months old and have been running them this way ever since. IT is functional too. The only thing hard to do is if you want to make the turn signals functional. My Sprint has cut outs for the stock turn signal housing whereas this scoop does not. I made my own housings and run the wires through the main opening.
__________________
"Todays racing technology has diminished the role of the driver way too much. Back in the days of 4 speeds, the driver had a lot more to do with the outcome of the race, and I can't imagine anything being more fun than that." Ronnie Sox
Mavaholic is offline   Reply With Quote
Old 2002-06-30, 09:19   #4
roadrage
Roadrage
Thumbs up Nice!
hey mavaholic,
it looks beautiful. of course mine will be flatblack, and i could care less about hooking up the turn signal indicators.
i might go a step further and add hood lock pins.
i used to have a 69 torino cobra jet, and was in love with the whole hood treatment.
is there anyway you can provide an underhood pic of your "ram air" setup?
im assuming that if it is functional, you had to borrow/create some special kind of air cleaner to make it functional.
as for the grabber hood....
i like them as well, but dont happen to have a grabber hood.
i could probably install the hood scoop for less than i could get a grabber hood.
also, has anyone ever made the grabber hood a functional "ram air" setup?
keeping options open. i could go either way
rr
Old 2002-06-30, 12:05   #5
Stefan
Big Cheese
Stefan's Avatar
Images: 1794
Question
Quote:
I dont quite understand this part. Did I miss something?
__________________
Stefan
Webmaster
http://www.maverick.to
Quebec MCCI Rep
http://www.maverickcometclub.org
Stefan is offline   Reply With Quote
Old 2002-06-30, 20:10   #6
Mavaholic
Mavaholic's Avatar
Images: 20
The Ford hood scoop has turn signal indicators in the back of the scoop. I havent installed them yet in this one but you can see the cut outs for them. The housing for the lights hang below the surface of the hood so you have to cut your hood out for them. On my blue 77 the housings were stripped out so I just made my oun housings and ran the wire up thru the large opening. ON my Sprint (see next picture) I cut out for the stock light housings. Its a pain because you have to cut into the under hood bracing for this to work. Most of the aftermarket look alike scoops dont come with the cutouts for the lights.
__________________
Old 2002-06-30, 20:15   #7
Mavaholic
Mavaholic's Avatar
Images: 20
__________________
Old 2002-06-30, 20:18   #8
Mavaholic
Mavaholic's Avatar
Images: 20
__________________
Old 2002-06-30, 21:38   #9
Stefan
Big Cheese
Stefan's Avatar
Images: 1794
Thanks for the info, you learn something new everyday!
__________________
Stefan
Webmaster
Quebec MCCI Rep
Old 2002-07-06, 22:43   #10
Thack
vision advicator
Thack's Avatar
Vehicle(s): 71 2 Dr Maverick, 70 Mustang Sportsroof, 77 F100 4x4, 72 maverick grabber wifes
Here's what I did to make the grabber hood functional.
Thack is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
scoop or grabber hood, Opinions/help wanted jeremy General Maverick/Comet 8 2006-05-24 19:14
4" Harwood Cowl Hood Scoop on Harwood Glass Hood Rick Book Technical 21 2006-01-30 17:26
A good day at the 'yards, and a neat-o hood scoop CACollo General Maverick/Comet 13 2003-06-02 06:00
Powered by: vBulletin
