8.8 Axle swap?
Discussion in 'New Members Forum' started by radicaldave, Jun 22, 2010.
  1. radicaldave
    radicaldave Member
    Denver Area
    1976 Comet
    I have a 8.8 explorer axle with 3.73 limited sliip.It is about 1 inch wider than than my 76 8".Any reason this wouldnt work in my 76 comet?
  2. starsky74
    starsky74 Technician
    Hackberry Louisiana
    Do a search, the pinion is way off center
  3. radicaldave
    radicaldave Member
    Denver Area
    1976 Comet
    I found nothing on search,however am just learning site.What effects from off center pinion angle?Thanks,Dave
  4. mav1970
    First thing that I would think of is that the pinion won't be centered in your tunnel so there would be, at least, a driveshaft issue :hmmm:
    And :Welcome: from Northeast Pennsylvania
  5. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    :wrongforum:you will get a lot more info in the tech area than here.
  6. gulupo
    gulupo Member
    nuevo laredo,Monterrey mexico, Laredo Tx
    1970 ford maverick
    My 1970 Maverick have a 8.8 rearend from a 1989 mustang gt, i swaped the 5 speed T-5 also. i have no issues with that because the driveshaft is also from the mustang. i didnt need to cut it, or make any mods to it.
  7. Bryant
    the drive shaft will be angled towards the passenger side of the car. it may interfear with the exhast and tunnel. it has been done. just be aware of that one problem.
  8. radicaldave
    radicaldave Member
    Denver Area
    1976 Comet
    Thanks,I found the it.I thought this subject had to have been discussed before.Sorry for the repetition.
