Normal RPM at idle.
Discussion in 'Technical' started by shaneb, Jul 21, 2011.
  1. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    What should the rpms be set to at idle? Right now my car is idling at 1,000 This is a 79 ford 302 5.0
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Between 600-800 RPM in gear
  3. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    I noticed you said in gear. If I have it in drive it should be around 600-800 and if its in park it should idle higher since im out of gear correct? Just trying to get the last things setup before I test drive it.
  4. darren
    Yep, you are correct. Have a fun/safe test drive.:)
  5. baddad457
    It should idle as low as possible and not stall in gear.
  6. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    I think I might have the dist too far advanced. I will check that when I get home as well.
  7. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    I change the dist a little bit and now its idling around 800-850 in park and 600-700 in gear. So I guess im where it needs to be.
  8. baddad457
    What's the initial ignition timing set at ?
