rear springs
Discussion in 'General Maverick/Comet' started by OLD GOOSE, Sep 5, 2011.
  1. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Does anyone know if a set of rear springs off a 1979 Mercury Monarch would fit a Maverick?
  2. Dave B
    I've tried to find the info on the net, with no luck. I don't think they do.
  3. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    The Data on this General Spring site shows them being the same length (55 inches), and same width (2.5 inches). The center offset-point is slightly different, if that matters.
    Double check this for me Dave, or Old Goose....I don't mess with leaf springs that much.
    Mav Data:
    http://www.generalspringkc.com/index.php?p=catalog&parent=105&pg=1
    Monarch Data:
    http://www.generalspringkc.com/index.php?p=catalog&parent=109&pg=1
  4. Dave B
    It's the spacing that's different, if you compare, the A&B of both, it's not off by much....
    Thanks for the link to the charts! (y)
  5. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Thanks for the info
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    What is that, 1/16" difference? Doubt you'd ever tell that little difference if you put on a pair of them......
  7. tody
    tody Member
    cologne, germany
    wow, the numbers are indeed pretty close. would give the opportunity of 5-leaf springs, nice!
  8. 71gold
    I wonder if the...spring eye bushings...are the same...OD & bolt hole dia...:huh:
