4 Speed Swap. Can we get it all clean in one post?
Discussion in 'General Maverick/Comet' started by xpsnake, May 1, 2004.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I have a stock 302 '77 Maverick that is getting completely stripped in the next few weeks. The car has a c4 in it and I would love to convert to a 4 speed top loader. Those of you with the infomation, I woud love to know EXACTLY what I need for this swap. Reading some of the other posts just confused me so I though I would try this.
    I very well know that I need some sort of pedal/linkage assembly, but whats the best way to go about it?
  2. xpsnake
    xpsnake Bruce
    Ok, I got this list from a post by dmhines. Can someone explain to me the "cable conversion" everyone is talking about?
    Clutch Pedal
    Clutch Pedal Pad
    Brake Pedal
    Brake Pedal Pad
    Pedal Bushings
    Clutch assist spring & bracket
    Rod from pedal to equalizer bar
    Clutch rod boot at firewall
    Clutch equalizer bar (Z bar)
    Frame side Z bar bracket
    Engine side Z bar bracket
    Bracket bushings, C clips and felts
    Rod from Z bar to clutch fork
    Z bar springs
    Bell housing
    Engine block plate
    Pilot bushing
    Flywheel
    Clutch disc
    Pressure plate
    throw-out bearing
    Clutch fork
    Clutch fork pivot
    Bell housing boot)
    4 speed toploader transmission
    4 speed shifter
    Upper shift boot and bezel
    Speedometer Cable and Gear
    Transmission Cross Member
    Transmission Insulator
  3. Mavaholic
    There is at least 3 ways to disengauge the clutch, once the pedal is pushed in. The original way was by mechanical linkage. V8 linkage is very hard to find in decent shape. 6 Cylinder stuff is easier to find, plus, you can use Mustang stuff. Modification on the cross ( Z ) bar is usually required to go this route. The second way would be to go with a hydraulic set up. There are kits out there to give you everything you need (as long as you already have a clutch pedal) to hook it up. They are, however, pricy. Around $450 for a toploader set up. The last way is a clutch cable, like the set up on late model Mustangs. This requires modification of the clutch pedal to accept the cable. Plus, the cable set up pulls to disengauge the clutch, which wont work on a toploader. The bell housing is designed to be pushed. Now if you decide to go with a T5, you can get a T5 bell housing which is set up for cable operation.
  4. rx7351w
    rx7351w Member
    knoxville, tn
    74 2 door Maverick
    I have a newer model toploader from an 81 capri. It uses the cable set up. I have the cable and pedals in but havent installed the tranny or engine. I followed Blown76Mav directions. They are in this thread http://mmb.maverick.to/showthread.php?s=&threadid=6207 I do have some before and after picture of the pedal boxes.
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Frank ... I bumped this to the top for you ... a list of parts ...
  6. 71gold
    dan,
    thanks, i got it (y) ..frank..
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    FWIW:
    I found all the Maverick stuff except the pedals.
    I got the entire pedal assembly from an early Falcon, hoping it would bolt in.
    No dice, BUT, I was able to take the clutch pedal from the assembly and graft it into my bracket, right next to my auto brake pedal.
    Some slight trimming here and there was needed.
    I also had to cut down my brake pedal and shape it like the brake pedal on the Falcon part, in order to use the pedal pad off the Falcon part.
    The point here is:
    Don't let slight differences between Ford models slow you down.
    Get a pedal assembly cheap or free from any early Ford, and go to town with it.
    I got my pedals given to me and made it work like stock. Saved a bunch of money and energy trying to get an original. Plus I knew mine was rebuilt right, rather than risking a worn piece of junk from a stranger... that would need going through anyway.
    Good luck
    Dave
    Btw: I also used an 11" bellhousing/flywheel to get better clutch design in there.
    They are commonly found on 302B and 351C/W engines. The SBF is 10.5".
    Don't use a truck bell though, it is slightly different and should not be used on a car.
    It is .25" deeper, throws everything off and can damage the tranny as well.
  8. dmhines
    Cumming, GA
    If you have the skills and tools then doing some fabrication is not an issue. For me ... I would rather spend the extra time and money finding the correct parts and just put it all together with a wrench :)
