Suspension lifts??
Discussion in 'General Maverick/Comet' started by Scraperondubz, Oct 15, 2011.
  1. Scraperondubz
    Scraperondubz Member
    Oakland, California
    MAVERICK
    other than air shocks whats options do i have for lifting the rear of the car??? dont wanna spent too much money let me know thanks
  2. Craig Selvey
  3. predfan2001
    I found out by mistake that Granada leafs put the back up sky high.
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Add a leaf to your springs.
  5. Scraperondubz
    Oakland, California
    MAVERICK
    i will add leafs as well
  6. tody
    tody Member
    cologne, germany
    which springs did you use? where did you get them from?
    any pictures of them installed?
  7. bmcdaniel
    Decades ago I added a couple leafs from a junk yard station wagon, the rear of the car was up around my chest, and I'm 6'6". LOL. A chassis and suspension shop can re-arch your existing springs. If they get it too high you can add lowering blocks to dial it in.
  8. mavgrab302
    I put a set of general springs 4 leaf in my 71 and it sits way up... I have at least 5" from the top of my 255/60/15 to the wheel lip... I'm going to put lowering blocks in... I don't know how much lift you need... The 71 sits higher with these springs than my 74 did with air shocks...lol
  9. Jsarnold
    '72 Sprint
    If you want pictues of the result of adding one leaf to each rear spring, PM me. The lip is about 2-3" above the top of the 235/60/15s.
  10. predfan2001
    They came from a Granada but it was in the 80s so I'm sure they hadn't had a chance to sag much. It was so high the shocks were maxed out.
    before
    with Granada leaf springs
  11. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    lift kits are sold at any autoparts store for $15-20
    They are adjustable rear shackles, just jack up your car, and unbolt the shackles and replace with the adjustable set.
    http://www.autozone.com/autozone/ac...i&fromString=search&itemIdentifier=540393_0_0_
  12. Bryant
    the only way to correctly lift a mavericks rear end is with leaf springs.
    if you do it will air shocks or a spring kit for the shocks you are putting a load on the top shock mounts that they were never designed to take. it will eventually damage the shock mounts
    longer shackles will increase the leverage on the frame rail and can twist the frame rail. they also allow allot of side to side sway in the rear end of the car that can cause unsafe driving conditions.
    you can make your own springs.
    goto the salvage yard and pull a pair of springs that 2.5" wide out of a truck.
    bring them home and take them apart. now take your stock maverick springs apart.
    take the top spring for the truck and cut the eyes off of it.
    put that spring under the stock maverick spring.
    now you be creative in stacking the different leafs that you have to create different ride heights and stiffness.
  13. Bryant
    oh also you will want to put longer shocks in also. the nissan truck shocks are longer and have the correct mounting.
  14. sportyfamilycar
    KY
    (2) 77' Mavericks
    What model Nissan truck is needed to buy for to get the right shock? will any do?
  15. Bryant
    there has been a few threads in the tech section on it. i havent searched for them yet.
