Update on Peel & Seal
Discussion in 'General Maverick/Comet' started by klynam, Dec 23, 2011.
  1. klynam
    klynam Member
    Big D
    1975 Maverick
    Our carpet came in today, which put me on the track of underlayment.
    I was considering coating the entire cabin floor with bed liner - actually I'm still thinking about that - but searching here on the trusty forums, led me to a nifty product called "Peel & Seal." Basically this is a roof repair solution found at Lowes, but seems to also be used as a low-cost rival to Dynamat for sound deadening.
    Anyhoo - after searching on line I found the company that makes Peel & Seal here:
    http://www.cofair.com/roof.aspx
    http://www.cofair.com/peel_seal.aspx
    You'll see "Peel & Seal" in the lefthand navigation. But the page you land on is about another product called Quick-Roof which seems to be basically the same stuff just in larger rolls.
    And here is a link to an online retailer who sells both the aluminum and white versions of Quick-Roof in 18" and 33" wide rolls.
    http://www.gibraltarbrands.com/ProductCart/pc/viewcategories.asp?idCategory=2&pageStyle=H
    And here's something else that looks really cool from the same company...
    http://www.cofair.com/wind_waterguard.aspx
    Just fodder for the ongoing discussions...
    :thumbs2:
  2. rthomas771
    Peel and Seal being 6" wide makes it easier to apply. When I did my Maverick I cut it no longer than 10"-12" strips. I wouldn't want to try and do a car with 18" or 33" wide...nothing is really flat enough to justify that width. Peel and Seal sticks once it touches anything.
    [​IMG] [​IMG]
  3. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    that stuff makes me want to pull up the underlay i used and use that...looks so damn clean and nice to work with...did i ever have to fight the underlay i chose to use. i should atleast do my trunk with it, whats the weight like..is it light compared to other underlays? the rolls look small
  4. mav1970
    Beautiful - simply beautiful!! How thick is this stuff? :bowdown:
  5. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    post #38 (ok here is 10 letters)
  6. rthomas771
  7. mav1970
    To Lowes I then go :p
  8. rthomas771
    I have about 10 rolls in my Mav. 3 layers on the toe board/firewall to windshield pinch weld. 2 layers on the floor and 1 layer on the roof. I still need to go back and do the inside the doors and quarter panels...maybe inside the trunk. Each roll weighs close to 4 lbs.
    [​IMG] [​IMG]
  9. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Why the different layers? Wouldn't one layer be good?
    Rick
  10. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    Yea lowes carries the stuff, real good stuff; I used in my 4 door, gave some spring to the vinyl floor also.
    I would reccomend truck bed liner as well, inside
  11. sportyfamilycar
    KY
    (2) 77' Mavericks
    :thumbs2:, I forgot about roof, I may put some there too
  12. blugene
    Nice! Do you know or think it could let go from the roof?
  13. rthomas771
    I sanded and cleaned the metal good before spraying 2 coats of Rust Bullet over a two day span. I gave the Rust Bullet two more days to dry before applying the Peel and Seal. I didn't see any signs of the P&S letting go with the car sitting outside for 2 or 3 weeks in the 100+ degree heat with the windows rolled up. I even tried to peel it off to make sure and it wasn’t going to happen before having the headliner installed.
    [​IMG] [​IMG]
  14. Dave B
    I like this video:
  15. maverick1970
    maverick1970 MCG State Rep
    Missouri
    They don't carry it at the Lowe's in my area.
