Update on Peel & Seal
Discussion in 'General Maverick/Comet' started by klynam, Dec 23, 2011.
  1. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    OK WATER RUNS DOWN HILL PAY DAY IS ON FRIDAY. All self adhearing products start to seal around 40 degrees. Peel and Seal is clean product and looks good when finished like Dynomat. Does anybody know what was invented first? I DO. Peel and Seal can be removed in winter or colder weather with a blow dryer, putty knife-scraper and patiance.Also I know of another product thats brushable thats like the stuff they use on LEXIS Automobiles That is the bomb. AND REMEBER ALL THESE PRODUCTS ARE VERY FLAMMABLE. HAPPY NEW YEAR TO EVERYONE.
  2. 71gold
    ...:hmmm:...
  3. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    Roofing 101 ICE and water shield is a self adhearing product similar to Peel and Seal. They are both cold process products meaning they dont require heat-fire to install them to roof deck surfaces. TEMP needs to be above 40. You could use ice and water shield instead of Peel and Seal on the car but its more messy and not as attractive unless you use the brand Grace ice and water. No matter which product you decide to use the best way I have found is first clean meatal apply brushable asphalt roof primer let dry tacky and then install rubber product. A blow dryer- heat gun helps the installation procees . OK enough about roofing products. GOOD LUCK TO ALL YOU GIRLS AND GUYS WITH YOUR COMAVE PROJECTS.
