Late Model Radiators In Mavericks/Comets
Discussion in 'Technical' started by Rick Book, May 22, 2004.
  1. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Hey guys,
    I'm trying to fit the maximum size radiator in my '70 Maverick. I need the late
    model flow (cross - flow??). The engine is a 347 c.i. and will be used for
    drag-strip only.
    I was trying to use one that came out of my old '90 Mustang but it's just too big.
    Looks like the maxium size radiator I can use is 30-1/2" X 15-1/2" tall. The
    width is measuremed from just above the radiator support and the height is
    measured from the support up to the hood 'shelf' (lip at fender).
    I only have 1-1/4" available between the support and the balancer so I can't
    put in between the two. I can't put a taller one in front of the support
    because the outlet would be blocked.
    Can you guys tell me what size radiator you have (I've searched with little
    luck). Is it aftermarket? Does it cool good enough?
    Any pictures and/or help would be greatly appreciated.
    Thanks,
    Rick
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I have a Griffin aluminum 26x19 radiator (core size, tanks on side juuust fit between the frame rails). The lower hose is high enough it clears the crossmember and angles up and toward the motor. Only cost 190 or so from Summit. No tranny cooler, but I have a large Hayden external tranny cooler. Hmm, 1 1/4 isn't much space... I'll have to go measure but I think it's 2" thick, so it doesn't sound like it would work for you. I guess you have probably already looked into something like this and that's why you're asking the question anyway huh. :slap:
  3. Rick Book
    Rick Book Member
    Thailand
    Hey Matt,
    Thanks for the reply. Is your radiator sitting behind the support? (I don't even have pics of the radiator in it's original location). Also, I assumed the reason for the tight clearance was due to '70's only coming with 6 cyls. :confused:
    Got any pics?
    Thanks,
    Rick
  4. Grabber5.0
    Kansas City, MO
    71 Grabber
    I don't have it mounted yet, but yes, it does sit behind the core support. I still have to make the brackets (and finish the car :D). I have plenty of room between the core support and the balancer on my 77, maybe there is a difference. If I don't have any pics I will take a couple new ones of it sitting in place. Won't the motor sit too far forward if the frame mounts are reversed?
  5. Rick Book
    Rick Book Member
    Thailand
    :eek:
    Gone to search motor mounts posts.
  6. Grabber5.0
    Kansas City, MO
    71 Grabber
    I could not find any posts on it either, but I just went out and took a few pics of mine. They definitely would move the motor forward if they were turned around (swapped left/right). The front of the mount is almost flush with the frame it is bolted to, but the back of the mount sits behind the frame. Hard to take pics with the motor in the car, but here's a couple. I'd estimate it might move the motor forward at least an inch, maybe two.
  7. Grabber5.0
    Kansas City, MO
    71 Grabber
    Front side of mount: (grease? what grease? :D) Laying under the oil pan, looking up and out.
  8. Grabber5.0
    Kansas City, MO
    71 Grabber
    Back side of motor mount, very obvious how far back it sits:
  9. Craig Selvey
    Cottonwoods look to be in bloom. :D
  10. Rick Book
    Rick Book Member
    Thailand
    Thanks for the pics. I'll go check it tomorrow (just got back from a long day of watching races).
  11. Grabber5.0
    Kansas City, MO
    71 Grabber
    How did you manage to notice that, Craig? :D I think that's what it is, though I have never actually figured out where the @#@#%# cottonwood tree in the neighborhood his.... :)
  12. Craig Selvey
    Lots of them around Indiana.....would recognize it anywhere. Went to a car show yesterday. The cottonwood was so bad that it looked like it was snowing!!!
  13. Rick Book
    Rick Book Member
    Thailand
    Well, I got around to taking pics of my delima regarding radiator fitment.
    The following pic is the view looking at the passenger side motor mount from the front of the car.
  14. Rick Book
    Rick Book Member
    Thailand
    This is the veiw of the passenger side from the rear looking forward.
  15. Rick Book
    Rick Book Member
    Thailand
    Viewing the Driver Side from the front of the car.
