turbo 460 maverick looks stock
Discussion in 'Drag Racing' started by maverick88tc, Jan 27, 2013.
  1. maverick88tc
    maverick88tc Member
    athens tennessee
    73 maverick grabber stock 460 s475 turbo
    i used to talk on here alot a couple uears ago and thought i would get back on here and show you guys what i have done to my car it used to be a 2.3 turbo with a holset he351 turbo 25+ boost stock long block stock t5 stock 8 inch with a mini spool and 380 gears it went 8.00@89mph in the 1/8th fast forward 3 years and it now a 460 bbf .503 lift 276/286 duration summit cam 114 lsa hyd flat tappet torker 2 intake 950 carb shop blow thru spectre low profile carb hat still has cummins intercooler d3ve home ported heads with stock valves s475 borg warner turbo with 1.1 a/r exh. housing 15 psi boost it ran 1.75 60 ft 7.3@100 on pump gas slipping 30-40% thru converter now it has a lower stall from 3800 down to 2500 now with balloon plates c6 trans with good clutches and band with stock planeteries and shafts still has origional 8 inch with stock 300 gears and 15 dollar mini spool on 26x8x14 dot slicks any questions just ask should run mid to high six's on pump gas it wieghs 3260 with me in it no cage i dont know how to put pictures on here but you can see videos of both setups on my youtube page http://www.youtube.com/user/jtdandnme?feature=watch
  2. John Holden
    John Holden Member
    NJ
    That thing is badass!
  3. Joe Dirt
    welcome back josh, should ride out to the shop and check out the four door
  4. maverick88tc
    maverick88tc Member
    athens tennessee
    someone said you came by abra a couple weeks ago but i missed it i drive the maverick to work every couple weeks i will have to let you know
  5. mav1970
    Enjoyed every bit of your You Tube clips - did you ever post a project thread when you built the car? Would like to see how you fit all of that drivetrain in the chassis :thumbs2:
  6. maverick88tc
    maverick88tc Member
    athens tennessee
    i had to put a mustang 2 under it i have a couple youtube videos showing what i had to do to fit it in the car under the stock hood but no build thread because i dont know how to post pictures
  7. mav1970
    Do you have a link to your You Tube build clips? I'd be interested in taking a look :)
  8. Joe Dirt
    yup,the day before I passed you on,apd40 i'm working off harrison pike cross from,mizzels
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    love the low budget sleeper look! (y)
  10. maverick88tc
    maverick88tc Member
    athens tennessee
    The link in my orignal Post is to my YouTube page that's where all my videos are
  11. mav1970
    Thanks - I'll look again
