door striker adjustment
Discussion in 'Technical' started by doncomfort, May 20, 2013.
  1. doncomfort
    chillicothe oh
    Got my sub frame connectors installed and my driver side door is hard to open. Is the striker on the jamb adjustable or do I have to adjust the hinges to fix it?
  2. Craig Selvey
    Yes, the striker is adjustable. If you were not so far away, I would tell you to bring it over and we would adjust it.
  3. doncomfort
    chillicothe oh
    I appreciate Craig. You're not TOO far away, but its a long drive for a quick fix. Looks like I might need to add a shim or two. Gonna be a bugger getting the screws broke loose.
  4. mercgt73
    mercgt73 Member
  5. doncomfort
    chillicothe oh
    I remembered this post and was going to search for it. Thanks for finding it for me!!!!
  6. mercgt73
    mercgt73 Member
    No problem. :tiphat:
  7. Dave B
    It's not a problem, with the correct tool.....
  8. 71gold
    did you install the sub frame connectors on a drive on lift?
  9. Craig Selvey
    OH gosh.....let's not go there again. :D
    I could bring the RIGHT TOOL with me to Carlisle and we could fix it there.
  10. doncomfort
    chillicothe oh
    I might take you upon that Craig. Things like this bug me and it will drive me nuts, so I will give it a shot in the next couple days and let you know. :thumbs2:
  11. doncomfort
    chillicothe oh
    The muffler shop installed them. I dont know what its called but the car was lifted by its wheels not the frame. Russ told me that sometimes things sag over time and I might have to use a jack to push them up into place. Thing is, I have no top, so when you jack up the connectors it caused the car to bow outwards. I think thats what they did. It sits level and rides great, so I will readjust the door and fender gaps.
  12. Craig Selvey
    Have tools.....will travel.
  13. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I'm tempted to offer you a mini-vacation, my doors fit like cr@p. They were perfect before my bud stripped and painted the car. Now you have to slam them and there's a ridiculous gap at the bottom...
  14. doncomfort
    chillicothe oh
    I got it Craig! Lowes sells a screwdriver with a nut like the one you have. Its a 3 instead of a 4 so I ground the tip down to get it in deeper. Worked real well :thumbs2: I took a striker off one of the junk cars, mine was getting loose with age. Big improvement and door closes properly again. Thanks for all the help. :Handshake
  15. Craig Selvey
    Just happy my little tech article worked for you.:thumbs2:
