Original paint on metal dash
Discussion in 'Cosmetic' started by EFIMAV, Jun 3, 2013.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Did a search but can't seem to find info regarding what kind of paint is on the original metal dash. Lacquer or enamel? I have a 74. Thanks!
  2. Dave B
    I don't think it would be lacquer .
  3. rthomas771
    The early-mid 60's Ford used lacquer paint for the interior. Don't know what they used in the mid to 70's
  4. 71Mavrk
    71Mavrk Member
    Nevada
    What color is your dash?
    Paint Codes - Interior Colors
    Color Name / CodeColor ImageColor Name / CodeColor ImageLight Parchment
    Lucite® Code - 9355L (semi-gloss)
    [​IMG]Dark Aqua Metallic
    Lucite® Code - 9153LH (semi-gloss)
    [​IMG]Medium Saddle
    Lucite® Code - 9359L (semi-gloss)
    [​IMG]Light Blue Metallic
    Lucite® Code - 9147LH (semi-gloss)
    [​IMG]Dark Saddle
    Lucite® Code - 9358L (semi-gloss)
    [​IMG]Dark Blue Metallic
    Lucite® Code - 9152LH (semi-gloss)
    [​IMG]Light Silver Metallic
    Lucite® Code - 9265L (semi-gloss)
    [​IMG]Red Metallic
    Lucite® Code - 9262LH (semi-gloss)
    [​IMG]Light Sage Gold Metallic
    Lucite® Code - 9266LH (semi-gloss)
    [​IMG]Dark Red Metallic
    Lucite® Code - 9353LM (semi-gloss)
    [​IMG]Dark Ivy Gold Metallic
    Lucite® Code - 9356LH (semi-gloss)
    [​IMG]Charcoal Black Metallic
    Lucite® Code - 9354LH (semi-gloss)
    [​IMG]Light Aqua Metallic
    Lucite® Code - 9144LH (semi-gloss)
    Some of these interior colors from the Mustang come up in my '71 Dupont Ford Interior sheet.
    https://www.oldride.com/library/1967_ford_mustang.html
  5. Moneymaker 1
    Panama City Florida
    I can tell you that ordinary rubbing alcohol will remove the paint rather easily, learned that trying to get a sticker off of mine.
  6. Acornridgeman
    Wisconsin
    One of the main ingredients in Lacquer thinner is alcohol. Might be a clue to what the factory sprayed.
    Naphtha (lighter fluid) works well for old stickers and tape residue and it is very safe for most paints. Around here we use a product called "Goo-be-Gone" for sticky stuff like gum and tape.
  7. predfan2001
    I'm fairly certain that my 70 was shot with interior lacquer from the factory. I got the car with 6000 miles and original paint. Everywhere that the interior lacquer over-sprayed on the exterior (tops of doors and sides of roof over the doors), the paint was cracking. When I stripped the Pastel Blue off I found blue interior paint underneath in all of the areas that were cracking.
  8. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Thanks for the replies, 71mavrk, the dash color is dark blue. And, I think Acornridgeman is onto something. I tried a bit of laquer thinner on the ash tray and the paint didn't come off all that well. Enamel?
  9. 71Mavrk
    71Mavrk Member
    Nevada
    Well, talk to Dupont and ask what Lucite is. I think it is enamel.
    The only dark blue I see in my '71 paint chips is a metalic, 9152LH.
    Micah
  10. predfan2001
    Enamel is a softer finish than lacquer. Lacquer is a hard finish and that's why it cracks over time but it shines great when buffed.
    As far as I know there was only a medium blue in early Mavericks and some of the later ones had a lighter blue.
  11. 67fstbk
    67fstbk Member
    Albia Iowa
    74 grabber maverick, 67 mustang fastback
    what about orange interior color
    Can't seem to come up for the orange interor color for my 74 grabber. Any thoughts out there? I need the code soon.
  12. Jean Doll
    Palmerton, PA
    There is an orange interior color called Medium Orange Poly that was used in 1974. It was a semi-gloss color used on the lower instrument panel, glove box and ash tray. The Ditzler code is 60697. I'm not sure if that is the color you are looking for but it's the only one listed in the 1974 PPG Ford paint chip books. It's on a supplement page so there is no picture of the color.
  13. 67fstbk
    67fstbk Member
    Albia Iowa
    Thanks, just called my local oriely's where we get our paint and they can't make that Ditzler code go anywhere. Does anyone have anything else that might help me? I have the exterior orange paint code but I don't think it's the same for the interior dash as described here. I would like to get this right on.
  14. Craig Selvey
    Email/contact Dave Boyer. He is the orange interior expert and maybe he can help.
  15. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Dupont Lucite is Lacquer Dulux was their Enamel back then
