2006 Crown Vic front suspension
Discussion in 'Maverick/Comet Projects' started by italianmaverick, Jun 16, 2013.
  1. italianmaverick
    italianmaverick Member
    Goose Creek, SC
    2004 Maverick GT
    Hey I'm new to MMB but I'm working on a project and I figure I should start here for help with R&D. I started a page on FB under (1972 maverick grabber 05) check it out and I'll start posting here.
  2. 71gold
    :Welcome::Handshake
  3. mav1970
    Subscribed to your Facebook page but I'll have to give it a look tomorrow :thumbs2:
  4. italianmaverick
    Goose Creek, SC
    2004 Maverick GT
    Crown Vic compared to Maverick
    may have some tweaking to do.
  5. mav1970
    I would have to agree with you. Looks somewhat similar to a Mustang II set up
  6. mav1970
    What is the difference in frame width between the Crown Vic and the Maverick?
  7. italianmaverick
    Goose Creek, SC
    2004 Maverick GT
    Maverick is 31" o.d. from frame rail and Crown Vic is 34" o.d. from side to side
  8. italianmaverick
    Goose Creek, SC
    2004 Maverick GT
    The whole setup was $500 from a junkyard I found online. You could probably find a cheaper. Having it here in front of me i can tell it is beefy and it's no wonder why they put it on truck frames.
  9. mav1970
    What is the difference from the face of the rotors where the wheels bolt? I'm going to say your track will be to wide unless you can shorten the cradle but then the rack and sway bar will still be too wide.
    I am a believer in anything can fit in anything with a certain amount of work :D
  10. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  11. italianmaverick
    Goose Creek, SC
    2004 Maverick GT
    It's crazy.... but it's about a total of 8 inches. And i can't cut the cross member due to rack and pinion and the motor mounts. But with the right rims and flaring she'll fit. Then I'd match the rear.
  12. Dave B
    I have seen, somewhere on the net, where a guy narrowed a Crown Vic front end to fit whatever car it was going in....maybe on pro touring?
  13. italianmaverick
    Goose Creek, SC
    2004 Maverick GT
    Interesting. I'll look into that. I still like the idea of flared fenders. Thanks
  14. Krazy Comet
    Worst thing about those is the wheel backspacing, factory it's something like 6.5", maybe more... Any possibility of narrowing the assembly and then using shorter tie rods???
  15. italianmaverick
    Goose Creek, SC
    2004 Maverick GT
    I'm going to look into that. If i did I'd cut in 2 places, right pass the rack & pinion .
