seat belts & interior
Discussion in 'General Maverick/Comet' started by hawkeye, Nov 29, 2013.
  1. hawkeye
    hawkeye Member
    perth, australia
    1971 comet gt
    img_20131125_175524_original.jpg img_20131125_175654_original.jpg img_20131125_175558_original.jpg img_20131130_120500_original.jpg img_20131130_122100_original.jpg Just a couple of pics of the new seat belts and some more interior trim, not only did the upholsterers cover the rear parcel tray, they also cover the metal surround.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Looks great! I was wondering about covering the plastic side panels and they look sharp. More things to consider spending money on.
  3. Rasit
    Rasit Member
    SE Pennsylvania
    Great looking interior! Do the belts work mounted like that? I am getting ready to install a set of retractables and they pretty much have to be perpendicular to the floor with the belt coming out vertically or they will constantly lock up. Also by sharing the lower anchor point with the lap belt coming out from behind the retractable, isn't it chris-crossed when latched? I'm thinking I have to add an anchor point, one for the retractable and one for the end of the belt...
  4. CaptainComet
    They did a great job covering all those panels. Those rear quarter panels had to be a bear to do, with all the curves etc.
  5. hawkeye
    hawkeye Member
    perth, australia
    1971 comet gt
    I had to put the retractor on an angle to stop the belt from rubbing on the way out, it was folding over and locking up.the anchor and the retractor were shown to be bolted at the same point in the instructions with the anchor on an angle
  6. CaptainComet
    Something you might want to consider is installing a belt drop. It makes the angle that the belt crosses the seat much more comfortable. Here is mine below. It came out of a mid-90s Ford passenger van. Even though it is newer piece, it doesn't look out of place.
  7. Rasit
    Rasit Member
    SE Pennsylvania
    How did you fish the latch through the belt drop?
  8. mav1970
    Is that orange area, of your rear enclosures, painted on or is it something attached to the surface?
  9. CaptainComet
    It is a bit involved. The latch won't fit. You have to attack it from the other end. You take the belt all the way off the reel and then reassemble the whole thing. That means keeping it wound against the spring tension as you put it back together. A challenge, but doable.
  10. hawkeye
    hawkeye Member
    perth, australia
    1971 comet gt
    The rear panels are covered in vinyl.
  11. hawkeye
    hawkeye Member
    perth, australia
    1971 comet gt
    Yeah, will have to look into some sort extension there, as the belts are just long enough pulled out.
