1 3/4" headers UPDATED!!!!!
Discussion in 'Technical' started by Erick-Mav, Apr 28, 2005.
  1. ray-g151
    ray-g151 Member
    Hatboro, PA
    1971 Maverick 412w , 1969 Cougar 427w, 1973 Maverick 306w
    I've been keeping an eye on this thread for some time now. Over the winter
    I decided to build a new engine(347). Knowing i needed bigger headers,
    I checked far and wide. The hooker 6208 seemed to be the best choice for
    small exhaust port head,but I was looking for a header with a 3 inch pattern
    for my AFR 205 heads. Also I don't like how most of our small block headers
    crimp down at the exhaust port,like the hooker 1-3/4. 1st I ordered a set
    of custom headers from Accufab for a mustang, with intentions i may have
    to move a few tubes around, NO LUCK!, pass. header was okay,3 tubes on
    driver's side hit the firewall or steering,but both headers would not fit in at the same time. The tubes came too far out before they swept down, another
    $550 wasted. Round #2 ,I ordered a set from Crites, 1-3/4 tubes into 3-1/2
    collector ,and they build them with the 3 inch pattern flange. The only
    problems I see so far, the front 4 tubes drop down below my oil pan,the center rib of the shock towers need modification(supplied by Crites),and a oil filter relocator is needed. I will be trying them shortly and will post pics.
    If they don't work I will resort to my final option, custom headers by Kooks
    For only $1,750. ouch!!
    Thanks for all your help. hopefully pics shortly.
  2. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Holy Schmoly, Ray! You sure do put your pocketbook where your experimentation lays. I appreciate your willingness to do trial and error.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Tubular offers large tube headers for 289-302 that can be had with 3" port pattern.
    Forgot the part number.
    They are for 65-66 Stangs, you might call and see if they would fit a Maverick.
    With all the Mav headers they have, they might know if these will fit.
    They are 8 individual tubes if memory serves.
    Dave
  4. okibono
    okibono Member
    cali
    how big are the tubes, dave?
    We need some 1 7/8's that can fit a AFR 205/225 or a Victor Jr, Brodix, etc...
    (exhale...)
  5. jmgford
    jmgford Member
    Iowa
    Is it just a 90 degree adapter that is needed, or does the filter need to be remotely mounted?
  6. ratio411
    ratio411 Member
    Pensacola
    I believe they are 1.875" (1 7/8") tubes, not sure, don't have the book in front of me.
