1100 cubic inch, all aluminum, DOHC Ford V8, Gotta get one of these for the Mav!
Discussion in 'General Maverick/Comet' started by ratio411, Feb 6, 2007.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    Ratio411 was pretty close with that photoshop :biglaugh:
  2. scooper77515
    Boxed or bottled...still only needs to go 1/4 mile...:p
  3. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    It powered a Sherman tank! That is so cool and it was made in the 40's. To think, it took ford how many more years to just make a ohv engines for cars? Yet a tank had a DOHC before WWII.
  4. hotrodbob
    hotrodbob Member
    Leno bought this car from the Blastoline Bros. They build these big cars. Last year they built a 50's Indy roadster look alike.
    GM changed the trans to an Alison auto with O/D and then Leno sent it to Banks. He also chromed and polished a lot of the car. He cruises this thing every once in a while. He brought it to a cruz night in Burbank and it would barely fit in the driveway.
  5. redneckboy
    redneckboy Member
    conway ar, 72032
    74 maverick 2 door
    yall know the bore or stroke of this monster, hafta be huge by large
  6. stmanser
    Davenport, Iowa
    you are all forgetting one important thing.. with an engine that big, it has to be able to slow down, and maverick brakes wont cut it.. lol
    oh and one more thing.. the weight would literally make the ass end come off the ground..
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    5.4 bore
    6.0 stroke
    1099.9 cubic inches
  8. eddie1975
    Martinsburg, WV
    sold
    wonder if its a long rod or short rod engine ;)
    what kinda RPMS?:D
  9. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Kinda small......:huh: :biglaugh:
  10. eddie1975
    Martinsburg, WV
    sold
    starting to sound like that Iowa guy:p
  11. PaulS
    So with 1100 cu" in a zero point stock form you have 600 hp? Is that engine streetable in any application? You have to have 42 inch slicks to be able to keep from spinning the tires off.
    Do you think I can get one in basic Ford blue?
    Paul
  12. ratio411
    ratio411 Member
    Pensacola
    It's peak torque is around 2500 rpm.
    1200 ft/lbs IIRC...
    You would need some serious slicks to get it to hook.
    If it were a perfect world, money no issue, I would get a set of cams ground for it that would raise the peak rpm to around 5k.
    That would also serve to put the HP closer to, if not over, 1 HP per cube.
  13. ratio411
    ratio411 Member
    Pensacola
    You might be surprised that it doesn't weigh a whole lot more than a stock 460 or FE!
    As it is installed in the tank, it is 960 pounds!
    In theory you could shave that down some.
    Sounds heavy, but not really considering it's size.
    On another subject:
    I found some images that give a clue to the stock carb.
    It's hard to tell exactly, but it looks like a MONSTER 2v carb.
    The throttle bores look like they are 3" or 4" each!
  14. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Wonder how that engine would do in a Bronco rock crawler.:hmmm:
  15. ratio411
    ratio411 Member
    Pensacola
    Look like good tractor pullers...
    A pair, blown and injected...
