160 or 180 T-Stat truth or myth
Discussion in 'Technical' started by David74maverick, Sep 28, 2009.
  1. sierra grabber
    sierra grabber Certifiable
    northern nevada
    hmmm, maybe i over simplified by stating "like in your refrigerator", you are correct that the system is not set up exactly like a refrigeration unit.
    the methylene chloride flashes at 40 degrees making the coolant\water mix start removing heat at a earlier quicker pace but requiring back pressure to keep it from just gassing off immediately. this is to help overcome the MUCH higher boiling point of the ethylene glycol and the now modified boiling point of the water (due to the addition of the coolant). the liquids will still allow heat to leave via the heat transfer to metal, however the evaporation of the heat from the coolant water helps drop the temp faster before the liquid is returned to the block, but the properties of the methylene chloride also prevent it from causing the boiling point of the other liquids to drop, as boiling water is less efficient in heat transfer. BTW the "sweet odor" of coolant is not ethylene glycol so much as anyone who has handled it in its pure form can tell you, it is the brain killing Chlorinated solvent.
    http://en.wikipedia.org/wiki/Ethylene_glycol
    http://en.wikipedia.org/wiki/Methylene_chloride
    as a side note on the leaches, they are used in "medical grade" to help restore blood flow to severed and reattached limb among other things. i know this from a couple friends who lost fingers in sword fighting.... ;P
  2. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Another thing I can't figure out is why stores sale radiator flush stuff but it's illegal to dump coolant anywhere... and no place I can find will take it even if I was able to catch all that coolant... what do you guys do when you flush you radiator? or should I just take it to a shop and have them do it (I'd reather not to keep my costs down). Thanks.
  3. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    This threads is very interesting and informative and has triggered a couple of thoughts ...
    I've done way too much partying since I took that thermodynamics class back in the day:hmmm: AND don't take up sword fighting:naughty:
  4. David74maverick
    Arizona
    why not take up sword fighting... to many hits to the head?
  5. Mavman72
    Too many leeches and lost fingers.Sabers and eppes really hurt too.Foils just sting.
  6. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    '72 mav 2dr, '70 mav 2dr
    always awesome to see someone not polluting! If shops and local parts stores aren't working, call up your local recycling service and ask them. Besides, they are just going to purify it and reuse it so it behooves someone to collect it all. This stuff is very very bad for the environment. Great question to have on the thread.
    http://www.ecarcenter.org/az/az-antifreeze.htm -> for AZ
    also, contact your DEQ and they'll tell you where to go as well.
  7. bmcdaniel
    In our township they tell us to just flush it down the toilet, the sewage treatment plant will filter it.
  8. scooper77515
    I just drink the stuff. Packs an AMAZING buzz!
    Just kidding folks, this stuff will really kill you!
  9. sierra grabber
    northern nevada
    LOL ever since leaving the hazmat field i have also been unable to find someplace to rid myself of coolant. technically they can get you for dumping it in the toile\sink wast line but it is WAY better than dumping it in the street drain which usually doesnt even go through treatment plants.... and yes the treatment plant can seperate it but for some reason it makes them madder than dealing with the waste they do want?????? as for sword fighting, i aint stopping! doing a steel combat arena this weekend in fact hehe
  10. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    So that's what they put in the boxed wine...
  11. scooper77515
    :rofl2:
    Now get back over to my "eluding miss" thread...:p
  12. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    No shroud? :naughty:
  13. bmcdaniel
    I have that same fan. If the fan is within 1/2" of the radiator you don't need a shroud.
  14. scooper77515
    Will the shroud still improve the flow even if the fan is within the 1/2"?
  15. Bryant
    yes it would. that fan is not the most efficent set up.
