17 inch wheel and tire questions
Discussion in 'Wheels and Tires' started by Deerhog, May 30, 2021.
  1. Deerhog
    Deerhog Member
    Texas
    1973 Mercury Comet GT
    Hi everyone. I know there is a million threads about wheels and tires and I have looked at quite a few, but I just want a definitive answer to some questions I have. I would like to put 17 inch rims on my 73 Comet (5 lug). I've seen that many people run 7 inch wide wheels up front and 8 inch wide wheels out back, but I'd like to run 7 inch wide all the way around to keep it simple and to allow me to rotate tires. My main question is what the backspacing needs to be, and then if yall have suggestions on tire sizes I would appreciate that as well. By the way, if I go through and put new wheels and tires on my car, the original ones will be available if anyone is interested.
  2. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    If you want to know what you can run the answer will always be the same...measure YOUR car. I'm not trying to be smart with that, it's just that these cars are old enough, have been modified enough, and varied enough to begin with that what works on one car often doesn't work on another car.
    That said, it sounds like you've done a lot of homework on the site so you probably have a good idea what works already. Given that the rear already accepts a bigger wheel than the front, if you look at what's working for everyone at the front it is nearly always going to work on the rear.
    ike72com and BBMS18 like this.
  3. Deerhog
    Deerhog Member
    Texas
    I’ve never measured for new rims or backspacing so I’m not completely sure how to do that. I do know however that the car is completely stock and is still sitting on the original wheels.
    From the research I’ve done, people GENERALLY say that 4 inches of backspacing will work for a 17x7 all the way around. Any input on that would be appreciated along with tire size recommendations.
  4. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    ike72com likes this.
  5. TeeEl
    TeeEl Senior Member
    Colorado
    I run 17s on my Maverick. The ideal back-spacing for a Maverick is 4 inches. You can run 3-3/4" on the rear. You can run 4-1/4" if your tires aren't too wide.
    But yeah, 4-inch is perfect...
  6. TeeEl
    TeeEl Senior Member
    Colorado
    As for tire size with 17x7" wheels, I suggest
    225/45-17 (25 inches diameter) or 225/50-17 (26 inches diameter)...
    Comet79 and Static like this.
  7. Deerhog
    Deerhog Member
    Texas
    Thank you for the info! That's exactly what I was looking for.
