17" wheels??
Discussion in 'Technical' started by MAV T, Aug 15, 2014.
  1. MAV T
    MAV T Member
    Alabama
    1975 Maverick, 1972 Grabber, 1971 Grabber parts car
    I just found a set of wheels that I was told came off a fox body Mustang . Will they fit my 75 Maverick? Theyre both 5 lug.
  2. Dave B
    What's the back spacing? You'll probably need some sorta spacers.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I never knew that Fox-body Mustangs had 5-lug wheels.
  4. Bryant
    and the cobra was the only one that got 17s. but 5 lug conversions are very popular and affordable on the fox bodies so 5 lug aftermarket wheels are plentiful.
    wheel spacers will be necessary. i would guess that spacers around 3/4" to 1" will work. to get a better idea on the spacers needed we would need to know the width and the back spacing of the wheels
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    My 75 had similar wheels when I bought it. I removed them, I think it was 1 inch spacers all way round. Made the car ride like a covered wagon.
  6. MAV T
    MAV T Member
    Alabama
    I definitely don't want it to ride like that. I guess I will go a different way.
  7. Bryant
    you cant just assume that 17" wheels will make it ride like a covered wagon. (ive never ridden in a covered wagon so i really dont even know what they feel like, but i assume that its rough). to properly set up the car with 17" wheels the spring rates need to be changed and or the shocks to ones with proper valving.
    i personally like the more positive feel that a lower profile tire gives a car.
  8. jasonwthompson
    Carrollton TX
    You are right Bryant. I did not want to go through all that so I just put some 15 x 7 rims on and called it a day. I will admit the the 17's filled out the wheel wells much better.
  9. Shorty
    Shorty Member
    Lafayette, In
    Bryant is right again as usual. On my daily driven lowered Ranger during the summer I replace my 7" x 15" stock rims & 70 series tires with 9" x 17" & 10.5" x 17" wheels wearing 45 & 35 series tires, respectively. The truck takes on a completely different personality. It rides much firmer and I more actively avoid road hazards. But it also goes around corners like it's on rails! Recently I got to drive a friend's 2014 'Vette with similar aspect ratio tires. The suspension is engineered to work in conjunction with those wheels/tires and does not ride as stiff as my truck - even in "Sport" mode. Another friend's lowered S-10, on the other hand, rides like a log wagon even with 60 series tires.
    Bruce
