1963 Comet Automatic Neutral Safety Switch Issue
Discussion in 'General Maverick/Comet' started by mlgm8r, Apr 6, 2025.
  1. mlgm8r
    mlgm8r Member
    USA
    1963 Mercury Comet S22 Convertible
    Greetings everyone,
    New member here but have lurked on and off since picking up a 1963 Comet S-22 Convertible last Spring. Lots of great info on this site so I’m hopeful for some help with a NSS issue I’m having.
    Car has been finicky on starting for awhile and I’ve been successful previously by slightly adjusting the position of the exterior part of the NSS with the wire harnesses for NSS and reverse lights (this car has them - a cool design feature and space age rocketry looking highlight when “ignited”). I’ve been down the road of playing with the shifter but there doesn’t seem to be any significant sloppiness in the shifter assembly. I’m pretty sure that the problem is coming from the plastic electrical contact sleeve that is clipped into the inner shift column. It looks like the metallic (brass?) contact lines are worn and no longer completing the circuit to allow juice to the starter. Anyone know if these shift column contact sleeves are still available anywhere. I’ve searched but have been unable to find them or a part number. Any suggestions or help would be greatly appreciated!
  2. Powerband
    Powerband Member
    NY's \H/
    not familiar with auto's, sure someone here could help - if not try at:
    https://www.cometcentral.com/forum/
    Focused mostly on earlier Comet than 70's
    '63 S22 convertible is a special ONE YEAR orphan. First year of Cvt with small block six 200cid and first year with V8 available. Most all important parts also same as 63 Falcon.
    pics wood b nice...
  3. rthomas771
  4. mlgm8r
    mlgm8r Member
    USA
    Thanks for this information. I tried to post photos last night but was unable to select them to be included in the post after what I thought was uploading them. Will try again after work. The history of these cars (from the Edsel drawing boards etc.) is very interesting and one of the reasons I picked up the car is the availability of parts based on its Falcon sibling.
    I did go to cometcentral.com but they must be having a problem with scammers so they rot allowing new user to register.
    Photos to follow (hopefully).
  5. mlgm8r
    mlgm8r Member
    USA
    it’s the inner shifter column (first photo) that I’m fairly sure is the problem, rather than the outer column mounted switch with the wire harnesses. Anyone know where I can find (or refurbish) that inner plastic/brass connector sleeve the clips into the shifter column?
    Thanks.
