1967 Mustang disc brake setup
Discussion in 'Parts Interchange' started by joerockne, Apr 2, 2022.
  1. joerockne
    joerockne Member
    Norman, OK
    1972 Grabber Maverick
    Will they go on a 1972 Grabber ? My buddy has some he is not using. I see on the interchange guide the upper a-frames are the same ? Thoughts?
  2. Krazy Comet
    These?? Yes they'll work but you'll need to use the '72 bearings & races. Possibly the '72 tie rod pins will be too large fairlanediscbrrakes 002.JPG .
    joerockne and mojo like this.
  3. mojo
    Minium 15" wheels required for this setup? I like em!
  4. Krazy Comet
    Nope, I'm 99% were used with 14"... They were also used on '67 Fairlane, I don't remember seeing one of those with 15". With required brackets, fit the std drum brake spindle.
    There was a version used on full size Ford & Mercury, AFAIK those are larger.
  5. mojo
    If my car didn’t have the Granada conversion, I would opt for that setup.
  6. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I had a Mustang with the dual piston Kelsey-Hayes calipers and the 14” styled steel “GT” wheels.
  7. joerockne
    joerockne Member
    Norman, OK
    OK I was thinking maybe the whole spindle off the Mustang bolted right in ? You are talking about taking the mustang caliper and rotor and putting it on a maverick disc brake spindle I guess? I have drums at the moment.
  8. Krazy Comet
    No I'm talking about bolting the '67 disc brakes to any newer drum spindle.. For '66 & '67 drum & disc spindles were same, beginning '68 disc spindles became different. As far as backing plate bolt pattern, drum spindles were same '66-'75.
    You can use the Mustang spindle, will save switching bearings. From '66, Fairlane, Torino, Falcon, Mustang, Ranchero, etc spindles all can be swapped to Maverick. Includes UCA as well as LCA. In spite of popular belief, many parts can interchange.
    I know someone that owns a '69 Mach 1 that has '75 Granada brakes.
    As far as individual brake parts, there are three separate disc units, '66/'67(ONLY one that can use drum spindle). '68-'71 Falcon, Torino & plus mustang thru '73, and the Granada/Maverick units. For '68-up disc, spindle must match brakes. The Torino/Mustang is different from Maverick/Granada
    I have '69 Torino disc brakes on my Comet.
  9. joerockne
    joerockne Member
    Norman, OK
    OK I did not think the 67 Mustang brakes would go on the 72 Maverick drum spindle. Thanks for clarifying that. I will probably use them, because it will be super easy to do.
