1969/70 gas tank dimensions
Discussion in 'Technical' started by Moneymaker 1, May 11, 2017.
  1. Moneymaker 1
    Panama City Florida
    I have searched and cant find the dimensions for a 69/70 fuel tank for a Maverick, anyone know them length, width and depth?
  2. Acornridgeman
    Wisconsin
    I've got a couple here - will get the size for you shortly.
  3. Acornridgeman
    Wisconsin
    OK - here you go. Let me know if you need anything else measured.
    All figures are from the outside edge of the mounting lip.
    Left to Right = 27 1/2"
    Front to Back = 30"
    Depth at front side (sending unit side) = 7" - this tapers towards the rear of the car to 6" when you are 10" from the rear. Those last 10" taper much sharper and end at 3 1/2"
    The filler on center is 10 3/4" from the right - 16 1/4" from the left - and 4" from the rear lip
    The lip is equally set around the edge at 1 1/4"
    Hope this helps ........... :clap:
  4. Moneymaker 1
    Panama City Florida
    Yeah, it helps a lot but I was hoping for those measurements to be closer to the tank I found, thought it may be close, but no such luck, the dimensions on these new tanks are 24.5 inches wide X 32.875 length and 10 inch tapering in thickness, 20 gallon tanks, it was worth a try I guess.
