1970 ford maverick street drag project.
Discussion in 'Maverick/Comet Projects' started by bullet87, Nov 27, 2016.
  1. bullet87
    bullet87 Member
    farmington, maine
    1970 ford maverick
    Hey guys just looking to get some helpful info on my maverick build. I'm building up my 1970 maverick. Starting out I'm doing a v8 swap putting a blueprint 347 stroker motor doing a rack n pinion power steering and updating front end with disc brakes and 5 lug spindles. Got a 10 point roll cage to put in tci street fighter trans..haven't decided on trans 100% but leaning that way.. got a Franklin quick change rear end full posi trac. 12 gal race fuel tank. I'm pretty sure I'm going to have to tub it out for tires and rear end to fit.. just looking for any info on anything on this type of build would be greatly appreciated. Especially the back half fabrication. I'm doing this all by myself with a help from few friends.
  2. Rick
    Rick G8I operations
    Ocala, Florida
    Go big, since your doing the front rack I would suggest you start with a 351w based engine.
  3. bullet87
    bullet87 Member
    farmington, maine
    1970 ford maverick
    Been thinking about it just want to get as close to full on race car but still be able to take out for ice cream
  4. 71gold
    I would suggest building a street car and drag race it...:huh:
    Hotrock likes this.
  5. yellow75
    Tillamook Oregon
    If you havent got the engine all ready you would be better off going with a stroked 351 doesnt cost much more if any to build and car would be lots quicker or if you are not a purist an LS motor will give you lots of bang for the buck since you changed out the front end the sky is the limit.
    Sounds like a fun build with a clean slate to start with
  6. mgabski
    mgabski Member
    1973 Maverick
    I agree with the 351w based build. can make same power as 302 based engine more reliably and with less wear and tear on engine.
