1970 maverick, trans crossmember v8 issues
Discussion in 'Transmissions' started by Ford Freak, Dec 29, 2018.
  1. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    I swapped a sbf, and a 4 speed toploader
    Where it originally had a 200 i6 with a c4
    My issue is the hooker long tubes on the passenger side , will interfere
    I have a stock, crossmember
    And I have a v8 71 -77 crossmember
    Willing to trade for another 70 trans crossmember
    So I can get it welded or if you guys have any suggestions.
  2. yellow75
    Tillamook Oregon
    The 71-77 v8 crossmember can be made to work on the 70, you just have to cut a little out of the center section to fit between frame rails and slot the bolt holes on one side.
    Use your 6 cylinder one as a guide to see what you need to do
    Ford Freak likes this.
  3. Acornridgeman
    Wisconsin
    Agree with Mike's post. You need to just do a little modification to the 71-77 V8 crossmember to fit the 70 but it will fit fine.
  4. Ford Freak
    Thank you guys
    I’m going to give it a try
    Talk to
    You guys soon
    Also happy almost new year!
  5. Ford Freak
    So I’m getting back on the trans issue, got a few parts here
    Got a another trans mount
    Off a 6 cly car.
    Searching for my v8 71-77
    Stamped one
    Trying to upload a pic , but it is being slow to load
