1971 Comet door panel removal
Discussion in 'General Maverick/Comet' started by mrcomet, Jan 25, 2018.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    I've been reading all the threads about removing door panels. But most seem to be for 73 and up. I have a silver plastic piece between the arm rest and the panel. Will that come off after I remove the arm rest and the door handle? Or will it need to be pried off as I have seen some reference to a "cup" behind the door handle.
    Thanks for the insight!
  2. 71gold
    it should come off with the arm rest.
  3. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Cool. Thanks! Knowing that I feel more confident giving it a try now.
  4. yellow75
    Tillamook Oregon
    1/4" drive long 3/8" socket can be your friend for removing bolts that hold arm rests on, long flat blade screwdriver to get to clips that hold door panel on, be careful . Have to take little sticky emblem off of window crank to get to screw that holds crank on, if you are careful you can reuse it.
