1971 comet gt
Discussion in 'Maverick/Comet Projects' started by 7D2 Grabber, Jan 9, 2012.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Time to disassemble the steering column. Get your hammer out and go to work by separating the main shaft from the column.
    This is what the shaft looks like when it's out.
    Then separate the inner tube from the outerwith the same tool you used for the main shaft. The tape is there to let me know where the bracket lined up. I only had to remove and inch from the outer tube then I reassembled the column. Also don't forget to trim the little arm from the inner tube. It will interfere with the install.
  2. 7D2 Grabber
    7D2 Grabber Member
    Took me a while to get this sucker put on against the rag joint. Two people should knock it out fairly quick.
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi 7D2 :
    Been noticing your posts . We also are converting a 72 MAVERICK to the Borg Setup and we have experienced some " clearance " issues with rag-joints and firewall clearances. Although " your" rag-joint flange looks a little shorter than 'OURS' .. Is it a Borgenson Item ?? Just curious . We (C.A.M.E.O.) have been exchanging information with Everett (MoJo) in Illinois who is also converting his COMET with the same items. We've posted some photos showing some of the completed work on the unit WE are converting if you're interested. We think your Comet is
    coming along nicely and appreciate the work you've performed thus far. Lemmeno if we can be of any help along these lines. cameocarclub@yahoo.com
    Cometized
    (Chip)
  4. 7D2 Grabber
    7D2 Grabber Member
    My box is not a Borg unit, a company in southern CA is producing the boxes ABS power brakes - http://www.abspowerbrake.com
    I've had no real issues besides getting the correct pitman arm. But that appears to be resolved now. I could have clearanced the firewall to make it an easier install but it is not needed. I'm available at aguilar_w @yahoo.com as well but if you respond to this thread or my pitman arm thread I can respond with information that might help.
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi 7D2 :
    Glad to hear you've got your unit installed. Us too ! We made a provision to add more clearance at the firewall
    area to accommodate the rag-joint . Looks like "your" adapter is a bit shorter and a small amount of room sometimes makes a huge difference . We've also made provisions to add more 'caster' and we're waiting until the engine is in place and then a good 'alignment' and we'll see how it handles then. We've noticed that a lot of people are unhappy with the 'stock' antiquated steering set-up by Ford . By the way .. Nice work on your car.
    Cometized
    (Chip)
  6. 7D2 Grabber
    7D2 Grabber Member
    Thanks for the kind words, there is a local guy that I runs the ABS box and has had great success with it as he tracks the car in national events. His shop specializes in early mustangs but they can build anything. A friend of mine had them set him maverick up. https://www.mikemaierinc.com
    If I had to do it again I'd use his products due to customer service and he races what he sells.
  7. 7D2 Grabber
    7D2 Grabber Member
    It's been a while since I posted but I got the front bumper installed and painted the GT grille.
    Craig Selvey likes this.
  8. x72COMETx
    x72COMETx Member
    Vallejo CA
    That looks awesome
  9. 7D2 Grabber
    7D2 Grabber Member
    Before the bumper, sits a little high in the rear with the new rear leafs
  10. z28th1s
    Lynchburg, VA
    Looks good!
    Now you just need to get you a silver paint marker and paint the flat surfaces that outline the left and right side of the grille and the flat surfaces that outline the turn signals.
  11. 7D2 Grabber
    7D2 Grabber Member
    Yea I need to get one of f those pen markers to finish it off
  12. 7D2 Grabber
    7D2 Grabber Member
    Canuck and z28th1s like this.
  13. z28th1s
    Lynchburg, VA
    Very nice! Makes the front end look complete.
  14. mojo
    Have you driven the car since installing the steering setup conversion? The box looks exactly like the one on my car.
    I am interested to see what in the way of alignment specs you have; if you have had it aligned? I have and still have issue at speeds over 60 w/ the steering sensitivity/wandering. As long as, I stay below that - no issue. I hve all new suspension, steering parts and tires. I ordered a shim kit to install in the GM pump, hopefully to cure this problem.
    Cometized "Chip", has a similiar setup, but he runs a serpentine setup w/ later model pump -- say's his car handles great. Maybe his pump doesn't need the shim setup -- pressure probably lower than earlier gen. pump.
    I see you have little different setup, also. Later Ford pump and serp. belt system. Still interested in the steering question.
  15. 7D2 Grabber
    7D2 Grabber Member
    I haven't had it out yet, I have an ABS brake integrated PS box with a KRC aluminum pump. Should be a couple weeks until i do.
