1971 comet gt
Discussion in 'Maverick/Comet Projects' started by 7D2 Grabber, Jan 9, 2012.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I used a mustang sn95 driveshaft, just swapped out the small yoke flange with a big yoke flange and a 1310/1330 u joint
    This is the stock c4 1971 Comet driveshaft next to an SN95 mustang driveshaft
    The flange yoke needed for the conversion
  2. 7D2 Grabber
    7D2 Grabber Member
    Explorer rear end installed on of a dirty undercarriage
  3. 7D2 Grabber
    7D2 Grabber Member
    Off jackstands
  4. Dave B
    Looks awesome, did you weld the tubes to the centre section?
  5. 7D2 Grabber
    7D2 Grabber Member
    No, It won't make enough power twist them.
  6. blugene
    blugene Senior member
    Off of the stands has to feel great! :cool:
  7. junrai
    junrai Member
    rancho cordova ca
    whats the name of your buddies shop Im in rancho cordova and Im going to need atleast one roll cage built and I would like to ditch the shock towers as well so theres plenty of work to be done on my car if his prices are affordable on my busted budget.
    if your in town let me know you can stop by my place since apparently you get out this way. you can check out mine and my sons comets. who knows maybe the next time youre in town my new motor will be done
  8. 7D2 Grabber
    7D2 Grabber Member
    He's not too affordable for the car guy on a budget but his work is top of the line. Big head motorsports is his shops name. The shop is in Loomis not too far from rancho cordoba. I'll lt you know next time I'm out in your area
  9. 7D2 Grabber
    7D2 Grabber Member
    No real work done, I just ordered my subframe connectors.
  10. 7D2 Grabber
    7D2 Grabber Member
    Got my subframe connectors from chassis engineering and had a chance to weld them up today.
  11. 7D2 Grabber
    7D2 Grabber Member
    Cool It, Thermo Tec sound deadner and heat control. I grinded down the spots with surface rust and coated them with rust bullet. Took a little bit to get the hang of it but I'm satisfied with the outcome.
  12. 7D2 Grabber
    7D2 Grabber Member
    Chris Alston chassisworks double adjustable shocks for the rear that mount in the stock location.
  13. blugene
    Very nice! I hope you have plans to beef up the mounting areas at the tops..
  14. 7D2 Grabber
    7D2 Grabber Member
    Going to install as is, they have the same mounting as the originals except they're flipped upside down. Alston didn't mention any issues with the mounting areas.
  15. junrai
    junrai Member
    rancho cordova ca
    did you have your parts shipped out or did you pick them up? his shop isnt anything I imagined atleast the little show room I saw wasnt anyway
    I expected MUCH more I dont know what. but I expected more. maybe I expected to see cars on display they worked on
    I guess thats a good thing they focus on the work they do. not the look of the business.
