Average User Rating:
5/5,
Ownership Satus:
Currently own it
Year:
1971
Engine:
Other 8 cylinder
Color:
71 ford dk ivy
  1. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Jdb submitted a new car to the Garage :
  2. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Nice car. I think you’re achieving what a lot of members would like to do; swap in a smooth running V-8 with a good cam, heads, intake manifold, 4 bbl and 1.6 rockers.
    Then you put a can put a set a mags on it. :bananaman:
    MD
  3. Jdb
    Jdb Member
    California
    71 maverick 2 door
    I bought the willwood front brakes last week and planning to install after thanksgiving. Got the 15×7 bullit rims set. but right now im trying to figure out how my column shift linkage will hook up due to v8 swap. Looking for the 7A026 mechanism parts.
  4. stumanchu
    stumanchu Stuart
    Portland, OR
    Welcome to the forum! Mine was a 6cyl swap that was unfinished, but it came with headers and the column shift linkage I had gave me so much grief that I wound up using a Granada shift cable. Having a transmission out of a Granada made that easier though. Keep at it.....looks nice so far!
  5. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Can you post a picture of the linkage set up thank. Currently trying to figure out my 71 maverick column shift linkage hook up with 302
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    copy and paste C4 column shift linkage + longtubes
    into the search box and a thread with my pics and another pic without power brakes (a better bracket than mine) should be there. My transmission had a place to bolt the cable to the bell housing as it was a Granada transmission. If you go that route, you may need to fab a bracket to hold that end of the shift cable. There is also a link to buy the cable from rock auto, which will save around 25 bucks over NAPA. It will pull this thread up too now that I typed it here.....:slap:
  7. Jdb
    Jdb Member
    California
    71 maverick 2 door
  8. Jdb
    Jdb Member
    California
    71 maverick 2 door
    I posted this picture so you can see linkage for the column.
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    Yes sir! I definitely had 6 cyl linkage.....the v8 stuff would be the way to go if you dont have headers...or have good headers designed to work with the linkage. I had to get a power steering drop bracket too......and dimple a tube that the steering arm hit. nice diagram.
  10. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Hipo exhaust manifold is the one i used due to the gt40p head spark plug design. Not sure how will the pipes going to interfere with the column linkage.
  11. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Hipo exhaust manifold ford
  12. Maverick Dude
    Type 289 Ford hi po in the search function. There are some opinions on it.
    MD
  13. Jdb
    Jdb Member
    California
    71 maverick 2 door
    Yes it is pricey though thats the one i used for the gt40p heads
