1971 mercury comet Help with front and rear brakes.
Discussion in 'Parts Interchange' started by MattGBE, Jul 11, 2015.
  1. MattGBE
    MattGBE Member
    71 Mercury Comet
    Hi Guys,
    I am over in Australia just picked up a nice 1971 mercury comet in good orginal condition.
    My problem is nobody knows anything about these things on this side of the planet.
    Hoping I could get the info I need to start doing some mods.
    My car- 1971 comet LHD/302/auto DRUM brakes all round.
    I would like to do a front and rear disc brake conversion and front coilover conversion to match.
    I have being doing a bit of hunting around but cant get the info I require or need considering I will have to buy from the states and bring parts in. So I want to be confident everything will fit etc.
    ANY HELP WOULD BE MUCH APPREICATED.
    Cheers Matt
  2. 71gold
    good morning,
    an RC-107 kit will give you everything you need and more. the rear Disc from a Crown Vic. is an almost bolt on conversion...:thumbs2:
    Frank
  3. Krazy Comet
    Welcome!!
    Assuming you want to keep it orig , the '68-'71 Fairlane, Torino, Falcon, Cyclone, Ranchero etc fits, as do '68-73 Mustang Cougar(all these are same brakes)... Spindle, bearing & tie rod pin size increased from '69 to '70 on all...
    Most swappers use '75-80 Granada brakes that use different components than the Torino/Mustang... This used to be a cheap swap, but supply of those cars are almost gone...
    Now days it's probably less expensive to go aftermarket and not swap spindles, excepting for center link, everything for a '70 Mustang will fit your Comet...
