1972 calipers
Discussion in 'Parts Interchange' started by Cometrider42, Feb 25, 2017.
  1. Cometrider42
    Cometrider42 New Member
    Knox, pa
    1972 mercury comet
    Will 1974 calipers fit a 1972?
  2. Krazy Comet
    If you mean for a drum to disc conversion, not unless you swap to the '74 spindle as well...
  3. rthomas771
    Even with the correct disc brake spindles there are more to it than that. Brake lines and hoses, master cylinder come to mine. Factory '72 wheels won't fit disc brake spindles...center hole is larger on disc brake wheels.
  4. Cometrider42
    Knox, pa
    1972 mercury comet
    It has factory disc brakes on it. I am missing the drivers side caliper though. The Auto parts store isnt showing one for 72 but is for 74. Auto Zone caliper says it is for a 72 comet is completely wrong.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    72 did not come with disc brakes, you will need to verify what they came off to ensure you get the correct piece. I would start with any casting number you can find and dive into the web for more info.
