1972 Grabber "Handling Suspension" option?
Discussion in 'General Maverick/Comet' started by Drifter69, Aug 17, 2021.
  1. Drifter69
    Drifter69 Member
    Maine
    '72 Maverick Grabber
    My '72 Grabber (302) was ordered with the "handling suspension" option according to the Marti Report. I've seen other '72 Grabbers with 302's and no such "handling suspension" option.
    Can anyone shed some light on this?
  2. Krazy Comet
    I don't have a '72 price list but HD suspension is listed for both '71 & '73(no I don't know if that's same as Performance).
    Included HD springs, shocks & front stabilizer bar, price 12.00 for '71 & 11.66, '73...
  3. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I ordered a new 71 Comet GT. I ordered the handling suspension package. It came with 4 leaf springs on the rear. I don't know but was told the front springs were heavier. Front sway bar was bigger. I do know it would take a curve faster than Mavericks or Comets with out it.
    Drifter69 likes this.
  4. Drifter69
    Drifter69 Member
    Maine
    Mine also came with AC. Could this have been a requirement for V8 AC cars due to weight?
  5. Hotrock
    Munroe Falls, Ohio
    Not necessarily, my `72 V8 non air has the handling suspension. Check out my Garage posting for the Marti report and specifics.
    Linked below:
  6. Krazy Comet
    I doubt it, generally A/C cars have increased load rate front springs only. My '72 Comet has A/C and rear springs are three leaf. HD springs were a option.
    At any rate 50, year old springs lost their HD rating probably 35 years ago.
    Ronald Hopkins likes this.
  7. TeeEl
    TeeEl Senior Member
    Colorado
    It was basically a "tow package" to get 4-leaf rear springs.
    Interesting though; I always thought the larger front sway-bar became an option in '75, but apparently it was earlier than that.
    That stuff would have improved handling slightly, but it was still a pig with the skinny tires and such a high stance...
  8. bmcdaniel
    What's the diameter of the bigger sway bar?
  9. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    IIRC 7/8.
  10. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Photo of mine after sanding, painting and new hardware. Taped over assembly marks, so the still show.
  11. Ronald Hopkins
    1972 Comet GT
    My 71 didn.t have air but I sat down with the sales man and an order sheet and ordered it exactly like I wanted. the way I ordered it came to $2888.00.
  12. TeeEl
    TeeEl Senior Member
    Colorado
    It's either 13/16" or 7/8", not 100% sure which. The standard bar is 3/4"...
  13. bmcdaniel
    My car has a 13/16" bar. I need something bigger but all I see are 7/8" bars. Would 1/16" larger make much difference?
  14. Drifter69
    Drifter69 Member
    Maine
    Here's what I came up with... See attached.
    (REF: https://eicac.co.uk/Torsion-in-Shaft-Calculator)
    Grabber72 likes this.
  15. bmcdaniel
    Thanks. I found an online calculator here:
    http://www.auto-ware.com/calcs/swaybar.htm
    From what I've been able to figure out going from my 13/16" bar to a 7/8" Maverick bar is a 39% increase in stiffness and going to to a 1" Mustang bar is an increase of 86%. The Mustang bar has slightly longer arms and that affects the rate.
