1972 Grabber "Handling Suspension" option?
Discussion in 'General Maverick/Comet' started by Drifter69, Aug 17, 2021.
  1. bmcdaniel
  2. 71Mavrk
    71Mavrk Member
    Nevada
    A while back, a bunch of us got together and had some 1 1/8 bars made up. There were a lot of issues getting them done.
    I have the thicker bar with my Total Control coil over front suspension. In the rear, I have Koni shocks, sub frame connector, traction master bar and a rear sway bar. I am amazed how well she handles.
    Maybe you guys can get together and see if Addco will do a front and rear bar again.
    Performance Sway Bar 1-1/8" | Maverick/Comet Forums
    Micah
    Drifter69 likes this.
  3. bmcdaniel
    I contacted Addco, they want $350 to make a custom bar.
  4. 71Mavrk
    71Mavrk Member
    Nevada
    That is why the group effort. I believe the cost went down dramatically when we ordered several.
    Micah
  5. Krazy Comet
    mavcometswaybar.JPG Here is Master Parts listing for bars. Varied by engine & whether or not HD option was ordered. The '73/'77 Comet listing shows a 11/16" bar std & 7/8" as HD, all years & engines.
    In this era I've not seen anything over 15/16" & that's on my 428 Cobra Jet with competition suspension.
    TeeEl and Drifter69 like this.
  6. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Here's a thread about using a 1965 Mustang bar at 1 1/8". A Google search found several threads about Mustang bars. Looks like the key is to slide the mounts forward just a bit by elongating the mounting holes and accept that the end links aren't exactly going to be perpendicular to the ground. http://mmb.maverick.to/threads/1965-1966-mustang-sway-bar-1-1-8-comparison.100185/
    I also have some info stashed away somewhere about mounting the stock, 7/8" front bar to the rear axle. It looked pretty acceptable, the size is right, and it was a very affordable swap.
  7. 71Mavrk
    71Mavrk Member
    Nevada
    Here is a picture of how I ended up installing mine. Also, if you go to my build page, there is an under side shot of the suspension. It is towards the end of the photos.
    Micah
  8. 71Mavrk
    71Mavrk Member
    Nevada
    Since there is discussion on the rear sway bar. Here are a couple of photos. This was during mock up. I reinforced the frame mount with 1/8 plate on three sides. The build page has some shots of the rear frame mods.
    Micah
  9. TeeEl
    TeeEl Senior Member
    Colorado
    I made my own brackets and end-links for the rear bar. Also welded plates to the frame rails as mentioned above. End-links have the polyurethane bushings on the bar ends, and rod end bearings attaching it to the frame...
