  1. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I used exhaust pipe in different diameters. The toughest part was to get the main piece rolled to fit perfect. It does not have the same curve on both sides of the dash.
  2. blugene
    You mean the cluster face?
  3. Cruzin Illusion
    1972 Grabber
    Got the Ashtray pretty much gone plus the gap on the right side taken care of. A little more metal work, getting the left side gaps evened out, and clean up the openings for the gauges and it will be off to primer.
  4. Cruzin Illusion
    1972 Grabber
    Yes. If you look at the plastic OEM piece it is not symmetric with the curve left to right. It just took a little more hand forming than to just put the metal in a roller.
  5. 71gold
    I take it, centering the gauges on the steering column was not an option.
  6. Cruzin Illusion
    1972 Grabber
    There is not enough room. The original gauges were not centered from the factory which is surprising to me.
  7. car-nut
    car-nut Glenn
    conn.
    Looks great. I am curious as to how you are mounting it?
  8. Cruzin Illusion
    1972 Grabber
    Tabs at the bottom like the stock cluster and 2 screws at the top which will be capped for a clean look. The screws will be inside a pocket so the caps should sit close to flush.
  9. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    The dash looks great! I can't wait to see it all together and in one color!
  10. Cruzin Illusion
    1972 Grabber
    Finished up the final work on the instrument cluster and dash, epoxied primed them and they are painted. The dash is 2 toned with the cyber gray in the middle and semi gloss black on the out side.
  11. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Looks amazing!
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Dash is looking good.....:thumbs2:
  13. Corbin Johnson
    Looks great!
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Very impressive.
  15. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Ive asked it in the past, but when do you plan on givin it to dad? Fathers day is approaching in a few months.
