1972 Maverick sport lights stay on
Discussion in 'Technical' started by Mav_Max1972, Aug 25, 2019.
  1. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    just put in my wire harness but my sport lights won’t come off they stay on no matter what I do and my switch doesn’t work to take them off either. Thanks
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Sounds like you may have a wiring problem.
  3. William623
    Orlando
    1973 ford maverick grabber
    Sounds like the factory relay might have gone bad and is staying in the on position.
  4. yellow75
    Tillamook Oregon
    I dont believe there is a relay for the sport lights, just power to switch and then to sport lights . Switch could be bad or the wiring has been changed at one time or another
  5. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Could it be that I got a open wire some were
  6. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    How can I detect the wire or wires that are bad ? And all my other lights work head lights turning signal break light etc
  7. yellow75
    Tillamook Oregon
    You need to have a 12 volt test light at the least and start at the sport light switch and see if when you turn it on/off it makes any difference, if the test light lamp stays lit no matter what the switch position is in then more than likely the switch is bad. You can unplug the sport light switch and if they dont turn off then you need trace wires from the sport lights to wiring harness plug on fire wall
    You say you just put in your wiring harness in could you explain more as to the reason for install
  8. Craig Selvey
    Yes....there is a relay for sport lamps. 1972 for sure. Maybe 1971 as well. It is located behind the drivers front kick panel.
    William623 likes this.
  9. William623
    Orlando
    A 71 I worked on awhile back had the relay but it was a later year model. My 72 for sure had it.
  10. yellow75
    Tillamook Oregon
    I stand corrected, it has been awhile since I dealt with a car that had sport lights but now that it is brought up about the location I remember. Good place to start looking
  11. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    I gutted it out to put an AC and new dash
  12. Acornridgeman
    Wisconsin
    I had a 71, and it does have the relay in the drivers kick panel. As far as I know all cars with the sportlamp option came with the relay.
    Interesting note - the wiring connectors changed for the switch from a 71 to a 72 harness.
    Craig Selvey likes this.
  13. rthomas771
    Is this what you're talking about?
    Mav_Max1972 likes this.
  14. Acornridgeman
    Wisconsin
    Yes, that is it - harness plug for the switch was different between the years.
    I would disconnect the switch and see if that kills the lights. If not, I would move on to the relay and check that.
  15. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Does any one have a picture of how the relay looks like ??
