Discussion in 'Maverick/Comet Garage' started by Howard Forbes, Jun 18, 2017.
  1. jacek
    jacek Member
    Los Angeles Suburbs- North
    1970 Ford Maverick
    BTW AJE has a setup now that allows to convert the front to SN95 style mc pherson front end and you can use stock spindles, brakes, rack and pinion, but you need coilover suspension. The modified shock towers apparently make room for the modular 4.6 32v
    In the rear there is some fabrication needed but you can install stock s/n 95 mustang rear 4 link suspension and the 8.8" rear end with stock style coil springs. I could probably swap most of mu bullit parts this way. May save quite a bit and have an easy access to replacement parts down the road. That is important as well.
  2. DGD
    DGD Member
    IND
    Bad to the bone !!!
  3. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    A very fine build.
  4. mojo
    I really like the low profile treatment done to that hood -- really tastefully executed. Never been a fan of the real tall hoods for a street driven car. What mod's were done to the towers? Much of the work done in home garage.
  5. Howard Forbes
    Howard Forbes Member
    Chesapeake, Va
    1972 Maverick , 1977 Cobra II
    The towers were moved 2 1/2” a side and I removed it from the fender side so they would keep there original contour. The hood was done by a friend of mine that did an amazing job grafting the scoop in . I own an auto repair shop so the majority of the work was performed there with access to lifts and equipment .
    mojo likes this.
  6. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    3 years, oh no, you're not done. Just the first chapter. Now you get to get all the bugs out of it. As you drive and play with it, you'll make little changes here and there.
    The never ending project.
    Howard Forbes likes this.
  7. Mustang1989
    Mustang1989 Member
    Corpus Christi, Tx
    1994 Chevrolet 383 Silverado
    Really like this car. It's all there, the stance, paint , powerplant.....etc. I'm not much of a 4.6 litre fan but can respect the amount of work it took to make all of that happen. One bad a$$ ride man.
