Discussion in 'General Maverick/Comet' started by JHodges, Oct 20, 2006.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The Ford Parts Manual shows 250 6-cyl used same drums as v8 when equipped with 10 x 2 1/4 brakes in 1971 or equipped with 10 x 2 1/2 brakes in 1972 ....
  2. JHodges
    JHodges thumper
    Dora Alabama
    I just bought this car because it was in far better shape than I thought it was
  3. mean_maverick
    i seen a 72 in a junk yard up here and it was originally a 250 car with 5lug all the way around
  4. Maverick Man
    California
    it probably a left over 71 sold as a 72. what date was the car made?
    my 73 has a 72 dash
  5. Craig Selvey
    All 1972 6-cyl cars were 4-lug.
  6. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    Craig,
    My Sprint has 5 lugs and its a 250. The 72 Grabber is 4 lug though. The Grabber was a 200 6 cylinder from the factory. I have seen several 72"s with 5 lug hubs over the years. Like said earlier perhaps it was an option that could be ordered. I know the hubs on the sprint are HUGE compared to the ones on my grabber. I have owned 7 or so mavs over the years and most of them 70-74 all of those were 4 lugs except two. A 73 4-door that was equiped with a 250 and the Sprint. My hubs on the sprint are way bigger though than the 73's 5 lug set up. Just throwing some more fuel on the fire.
    Thanks
    Jerryfow2
  7. Craig Selvey
    Jerry
    I would have to speculate that your Sprint was converted to 5-lug by a previous owner. I don't know for sure if it was an option or not. More Maverick mysteries!!
  8. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    This is interesting. Is there a way to check the rear end for any numbers? Anything that would let us know if the rear end was from another car? This might be a good poll for someone. I can honestly say the Sprint looks totally untouched. I mean the car has had very little done to it that I can see. Like you said, Mysterious isn't it! I will be pulling everthing apart this spring (new wheel bearings and brakes) perhaps we can find something fishy when I jump into it.
    Jerryfow2
  9. Craig Selvey
    I don't know of any numbers one can look at. If you can find a build sheet for it....that would help. Maybe a History 999 report???
  10. Acornridgeman
    Wisconsin
    Check the pumpkin tag - it will ID car application but more importantly it will give you a date code that should be very close to your cars build date.
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Sounds like another case of "Ford always put________[fill in the blank] on
    _________ [fill in the blank] cars" :rofl2: In other words, it's risky to use "FORD" and "always" in the same sentence. :burnout:
  12. Acornridgeman
    Wisconsin
    This sounds like the best explanation to me. Bigger brakes = bigger drums, which were the 5 lug drums. :yup:
  13. JHodges
    JHodges thumper
    Dora Alabama
    I don't know if this matters but this car was made in 9/71 but is titled as a 72
  14. dmhines
    Cumming, GA
    That makes sense ... new model year starts in September ... nowadays it sometimes starts much earlier ... 2008 Mustangs are already at dealers ..
  15. coutangman
    coutangman Member
    Charlotte, NC
    The Sprint I just bought has 5 lugs. The car is a 2 owner with original paint. The suspension looks original. It is a 250. I haven't got a Marti report on it yet to see if there was a special suspension option. I doubt it since there are no other options other than the Sprint option on it.
    Jim
