1972 mavrick 302 V8 2c BOSS ENGINE
Discussion in 'General Maverick/Comet' started by Prezz, May 8, 2006.
  1. Prezz
    Prezz New Member
    Hello all and good day! I made a post yesterday to try and figure out what my 72 maverick is worth. Here was the post
    "Hello all , I am trying to get an idea what a 1972 Ford maverick is worth . It has a 302 V8 2c engine ,64,000 original miles and factroy AC . It is in close to mint condition .The interior is original and close to mint ! Original paint /no rust and has been gargaged for the last 10 years . Thanks head of time for any help ! Prezz"
    A neighbor next door who is a car buff said the reason the car was more valuable was that it was a BOSS 302 .....is this true ? Thanks, Prezz ( Pete )
  2. don graham
    very seriously doubt that as no mavericks came with a boss engine. if it's a 2 barrel it's also not a boss motor. they did come with a 302. which makes it worth more than a 6. value is dependent on a lot of things. condition, rust?, 2dr/4dr, options, etc. very hard to tell without pictures.:)
  3. ME262_1970Maver
    ME262_1970Maver Heavy Metal Maverick
    Red Hook New York
    1970 Grabber 1994 Mazda 626 DX 191K
    :agreed: and:ttiwwp: can't believe I got that in there first! :rofl2: :rofl2:
  4. fredee
    fredee Member
    South MS.
    1971 comet
    Sorry to blow your gasket but no mavericks were offered with the boss motor. Also 1970 was the last year the boss 302 was offered and that was in mustangs.
  5. ME262_1970Maver
    Red Hook New York
    Didn't some Dealerships do conversion to the BOSS 302? I'm pretty sure I've heard that was done, in a different thread. But I personal have never seen a Maverick with a BOSS 302. I've seen it with just about everything else though! LOL:D
  6. scooper77515
    I keep hearing about the BOSS 302, but what exactly is the difference(s) between our 302 and the BOSS?
  7. fredee
    fredee Member
    South MS.
    1971 comet
    Boss 302 was a 4 bolt main block with a forged crank,rods and about 10 1/2 to 1 compression. It had cleveland style heads with large ports and canted valves.Also used a solid lifter cam. Was used in mustangs and cougar eliminators in 69 and 70.
  8. blugene
    73 Comet GT, 72 Comet GT, 2008 "Comet" (our boxer)
    Sounds radicle! (to the pocket book,LOL!)
  9. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    I have heard/seen of one maverick with a 302 Boss. The boss does not fit without either notching the shock towers or using the blue wrench and BFH to "modify" the original contours of the towers. So, I too doubt that this is a Boss car.
  10. scooper77515
    I never knew the BOSS was a completely different engine...I just figured it was a different intake and carb, maybe higher compression pistions, just possibly some better heads....
  11. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    the boss, is pretty wide when all assembled, close to a cleaveland
  12. Mavaholic
    Is your car a Grabber or Sprint model? Is it auto or manual? Column or floor shift? Buckets or bench seat? Interior and exterior color? A lot more info is needed for an honest evaluation.
  13. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I'm pretty sure David Poteat did not notch the shock towers when he put a boss 302 in his Maverick. I'll have to go back and look at the article again...
    Prezz, I hope you don't feel ganged up on about the BOSS. Your neighbor may be a car buff, but he is probably mistaken about the BOSS. We hear that alot, still have yet to see an actual BOSS 302 in one of them.
  14. Prezz
    Prezz New Member
    Mavaholic ! It's NOT a Grabber ....must be a sprint.(God, I sound ignorant) It has bench seats and a column (automatic trans) shifter,dark green paint with a tan (black trim on the seats ) interior.
    Maverick Matt !!! I don't feel ganged-up upon at all . I am amazed of the rapid reply to my post and all the opinions and help .
    My "car buff" friend says "boss" is stamped on the engine and is going to show me, hopefully tonight and I will get back with you all ASAP .
    Thanks for your aid and interest ! Prezz (Pete)
    I WILL POST PICTURES OF THE CAR AND ENGINE ASAP ! I don't have a digital camera but my friend does .:tiphat:
  15. Graybeard
    Graybeard Member
    Lawrenceburg Indiana
    Here is a Boss 302.
    Notice the rectangular valve covers,same as used on the 351C-351M and the 400 .In fact you can put Cleveland heads on a regular 302 and use a Boss intake to make what is called a Clevor (Cleveland-Windsor).The water passages must be modified but it can and is done.A lot of trouble but some people do it.
