1972 V8 brake size?
Discussion in 'Technical' started by 302yellow72, Jun 13, 2021.
Tags:
  1. 302yellow72
    302yellow72 Member
    Poulsbo WA
    1972 Maverick 302
    That’s helpful info. Do you know if they will work with the stock 14” Maverick wheels?
  2. dyent
    dyent Member
    vancouver bc
  3. TeeEl
    TeeEl Senior Member
    Colorado
    Really not trying to derail your thread. The reason I suggest a front disc conversion is because by the time you buy drums, shoes, wheel cylinders, bearings, hardware kits, etc., you're not saving much money by not converting to disc...
    71gold and mojo like this.
  4. mojo
    I agree w/ majority advocating do disk conversion seeing the need for rebuilding system. Sitting 18 years, system need rebuilding. No matter how you drive this car; disk will serve the experience better than drums.
    TeeEl likes this.
  5. 302yellow72
    302yellow72 Member
    Poulsbo WA
    1972 Maverick 302
    You all might have converted my thinking. Is the ‘74 manual disc/drum MC the one to go with for a manual disc conversion? I like the eBay setup that will let me use the stock wheels.
  6. Craig Selvey
    TeeEl likes this.
  7. 302yellow72
    302yellow72 Member
    Poulsbo WA
    1972 Maverick 302
    I ended up going with the eBay kit and was surprisingly impressed with the fit and completeness of the kit. Now I just need my wheels back from powder coating and I can test them out.
    plynch, mojo and Krazy Comet like this.
  8. TeeEl
    TeeEl Senior Member
    Colorado
    That's gonna be a definite improvement over the original brakes...
  9. PirateSteve
    PirateSteve Member
    Las Animas county Co.
    1972 Maverick 2dr, 302 automatic. 1974 Comet 4dr, 250 automatic.
    It may be true that in the case of a 69, numbers matching mustang. A disc brake mod could lower the value. Mavericks, a good disc brake conversion could only increase value. By increasing it's reliability. Disc brakes are dirt simple in comparison, self adjusting, and have far fewer moving parts to fail. And the stopping difference, even manual disc is far better than drum. Its a big noticeable difference. You're going to thank yourself. They look great.
    TeeEl, mojo and Krazy Comet like this.
