1973 250 six, auto 4 door Carb question
Discussion in 'General Maverick/Comet' started by Bigt73, Nov 29, 2022.
  1. Bigt73
    Bigt73 Member
    Nova Scotia
    1973 4dr 250 six auto
    Which is better value for the money, rebuilding the original carb or just replacing it with a new one?
  2. Acornridgeman
    Wisconsin
    I've rebuilt a lot of carbs in my time so I would not hesitate doing a rebuild if my carb was in decent shape.
    $40 ish for the kit and some solvent vs $175 or better for a rebuilt.
    The advantage to a rebuilt is no fooling around. 30 minutes to swap them out and you are done.
  3. 71gold
    30 minutes if they get you the right carb. the first time...:huh:
    mojo likes this.
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    With a serviceable core I'd clean and rebuild every time, but that's just me. Other than throttle shafts so sloppy they leak air or mixture screws that have been bottomed out so hard the taper is ruined, they're normally good as new after a rebuild.
  5. TeeEl
    TeeEl Senior Member
    Colorado
    "Remanufactured" carburetors are a gamble. There's so much shoddy work performed, and even mixing parts from different year and model carbs. If you (or someone you know) have the ability, it's better to rebuild an original. Oh, and any "new" carb you find for these cars will be made out of parts from China. That's not to say they they don't work, but rather an original is preferable...
  6. Acornridgeman
    Wisconsin
  7. Bigt73
    Bigt73 Member
    Nova Scotia
    Thanks so much folks. I will get the carb rebuilt!
  8. Craig Selvey
    Rebuild the original carb. Factory carbs are built/jetted based on the year and motor size. It's a gamble with anything else.
    71gold likes this.
  9. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I bought a rebuilt and had trouble with it after a few months. Luckily I did not send my original back to them and let them keep the core charge. I later heard of an older gentleman who owned a carb shop for over 30 years that still did work out of his garage. He said always go with the original, he rebuilt mine and no problems since.
    Craig Selvey, 71gold and TeeEl like this.
