1973 Maverick Ldo
Average User Rating:
5/5,
Ownership Satus:
Currently own it
Year:
1973
Engine:
302 - 8 cylinder
Color:
Pearl White with brown vinyl top
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Did you mean the Melvin’s one or the original one in place now.
  2. dyent
    dyent Member
    vancouver bc
    I think he may have been referring that your existing battery tray is in better condition than most.........
    David
    Maverick Dude and Craig Selvey like this.
  3. Maverick Dude
    Although rusted, the tray is pretty sturdy so I decided to give two coats of rust paint and I’ll deal with it later. I’m moving on to some light rust work in the wheel arches.
  4. Maverick Dude
    I used a 3M fiber wheel to grind out the surface rust in the front wheel wells and then coated the area with Rust Bullet.
    4061C30A-214E-4969-A870-F3A9FDAF7375.jpeg 6DAD41FB-AAE5-42F2-9870-80A917E64A0E.jpeg
  5. Maverick Dude
    The next step might be too much for the purists. This is a Bondo touch up with a rattle can paint job. No welding. Sorry.
    Once the Rust Bullet cured, I lightly sanded it and applied Bondo to cover the holes that were made many years ago then the previous owner installed mud flaps. After a few attempts to get it smoothed out using 3M sandpaper with a Makita 1/4 sheet finishing sander, I primed it and shot it with Ford Pearl White 9C paint mixed by Express Paints. I ordered the paint from the Internet a number of years ago and was relieved to find the paint could still spray but it clogged after the first coat. I’ll probably get more paint and do another coat.
  6. Maverick Dude
    2E2BAD2E-A931-4181-86EB-E5E2E9B3966C.jpeg F9DDD763-C467-449F-9B58-CA33D23C560A.jpeg B2817DD1-4D88-443D-A093-B0E9EF01910B.jpeg CE4D2715-0BFE-4236-89C6-17C993BAEBC9.jpeg I’m carrying on with this temporary rust repair. Maybe some day I’ll cut it out and weld. Here shots representing the rust area at the leading edge of the driver’s side rear quarter panel. I ground out the loose rust, painted the outside metal with Rust Bullet, sprayed the back with Eastman rust encapsulator, laid a 8” x 4” piece of fibreglass on the back, placed short 3M shredded fibreglass Bondo in the holes. I rough sanded it and will now apply 3M Gold Bondo to condition the surface for painting.
  7. Maverick Dude
  8. Maverick Dude
    For the final Bondo coats I used 3M Bondo Gold filler. Here are pics of the rough coat, then after sanding. It still needs some touch up. I used a Mikita 1/4 sheet linear sander.
    711B397F-53B6-44B7-BDA1-AECF1BCE0D62.jpeg 6AB79C77-5BFE-402F-9107-AD4B8329C755.jpeg 04F83F53-7A40-4693-9091-C24C88A41547.jpeg
  9. TeeEl
    TeeEl Senior Member
    Colorado
    Lots of potential there...
    Maverick Dude likes this.
  10. Maverick Dude
    Now to hand sand and blend the primer edges then spray the Ford Pearl White. The photo was taken under fluorescent lighting so the original paint looks yellowish.
  11. Maverick Dude
    Before I paint, I’ve moved on to some smaller rust areas. I have three places where it holed through in a smaller area. I am grinding them out and hitting then with Rust Bullet. Here is the first one.
  12. Maverick Dude
    8596A0C5-4ECB-4189-8C00-473C200A9191.jpeg Here is the same problem area covered in Rust Bullet. I’ll apply a second coat today.
  13. Maverick Dude
    Passenger side showing Rust Bullet applied.
  14. Maverick Dude
    Passenger side after applying Bondo Fibreglass, sanding and then applying Bondo Gold filler.
  15. Maverick Dude
    AAB5EC07-1312-4C3D-9765-79C27B79C2DB.jpeg Passenger side after applying Bondo Glazing and Spot Putty.
