1973 maverick wheels and tires
Discussion in 'Wheels and Tires' started by Carcrazy117, Apr 5, 2016.
  1. Carcrazy117
    Carcrazy117 Member
    Seattle
    1973 Ford Maverick
    Hello everyone I was looking at some 15x8 205/65/15 wheels and tires with either 4, 4.5 or 4.75 inch back spacing and I wanted to know if i would be able to fit 15x 8s up front with 205/65/15. It's a 73 ford maverick. Thanks in advance
  2. 71gold
    I think with a 205 8" rims are too wide...:yup:
    Grabber-1 and Carcrazy117 like this.
  3. Hotrock
    Munroe Falls, Ohio
    Maximum wheel width for that tire should be 7.5". The large back spacing my also be an issue.
  4. Carcrazy117
    Carcrazy117 Member
    Seattle
    1973 Ford Maverick
    Thank you both for your input it answered my questions.
  5. Hotrock
    Munroe Falls, Ohio
    One other point, the maximum back spacing is either 4.25" or 4.50" depending on your particular vehicle's wheel well dimensions.
  6. 71gold
    the "vehicle's wheel well dimensions" are the same. the height of the front end is what changes.
  7. Hotrock
    Munroe Falls, Ohio
    Missed the up front part. I was referring to the difference in distance from the rear tire edge to springs. the inner wheel well and the fender lip. I'm sure you would agree, all of our vehicles were not built the same.
  8. Carcrazy117
    Carcrazy117 Member
    Seattle
    1973 Ford Maverick
    ok so if i wanted to run 7s up front and 8s in the rear 15 inch rims and probably 245 or255/60 in the rear and 225-235-60 in the front. would that work, Im running all stock 73 suspension other than i bought the 800 lb leaf springs from general spring that a lot of people recommend. thanks guys for your help.:Handshake:
  9. Hotrock
    Munroe Falls, Ohio
    I personally have 225X70 14s on the front with 6" wide vintage wheels and a 8X15" wheel and tire combination on the rear. You can find several wheel and tire combinations in the garage section of this website under wheels and tires. Keep in mind, the wider wheels are on tubbed cars.
    NCFatBoy likes this.
  10. Carcrazy117
    Carcrazy117 Member
    Seattle
    1973 Ford Maverick
    Okay, ya I've checked out the page your talking about but I didn't know that those bigger tire ones were with tubed cars. So if I wanted to do 15 inch rims. Are you saying that 8 inch in the rear is too big for a stock 73 mav. If so, sounds like I should run 7's in the rear and 6's on the front. What do you guys think? Thanks
  11. Hotrock
    Munroe Falls, Ohio
    nd 255X60 15
    The 10" wide wheels are on tubbed cars.
    A 15X8" wheel on the rear with the correct backspacing is fine. I'm running an 8" rear wheel with 4.25 backspacing. Some owners are running 4.50"
  12. redcomet
    redcomet Member
    71 comet
    I'm running 60's in the front and back of car 2056015 in front and 2556015 in back
  13. x72COMETx
    x72COMETx Member
    Vallejo CA
    I just installed some 215/60/15s up front and 265/50/15s on the rear
  14. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    On what size rims? And a pic? :)
  15. x72COMETx
    x72COMETx Member
    Vallejo CA
    15x7 front and 15x8 rear
    Crazy Larry likes this.
