1974 Comet AC vaccum lines?
Discussion in 'Technical' started by Underhungsea, Aug 22, 2019.
Tags:
  1. Underhungsea
    Underhungsea Member
    Hurricane, wv
    1971 Maverick Grabber
    The hole that the factory lines should go through is open with no grommet or lines. If I buy a new grommet and same diameter lines where do i route them to?
    1974 250 6cyl
  2. Craig Selvey
    You will need a factory schematic to see where the lines go. Under the hood the vacuum lines go to the heater valve and the vacuum canister.
  3. Underhungsea
    Underhungsea Member
    Hurricane, wv
    Happen to know where I could find these schematics? And could I just buy vac lines that fit and a gromment to replace them?
  4. rthomas771
    Is this what you're looking for
    71gold likes this.
  5. Underhungsea
    Underhungsea Member
    Hurricane, wv
    I beleive so, my actual grommet in firewall and ac compressor lines are missing as well. So any ac diagrams would be appreciated
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Rubber vac lines are just rubber vac lines, nothing special about them. The grommet is about an inch thick with holes in it for the lines to pass through. If you want something close to factory, you may want to look at rubber plugs and then just drill the correct diameter holes for the vac lines. On an AC car there are 4 holes in the grommet, 3 vac and 1 power wire that energizes the compressor clutch
    See stolen pic below.
    Krazy Comet likes this.
  7. Underhungsea
    Underhungsea Member
    Hurricane, wv
    Do you know where the lines/wire go to? Thanks in advance!
  8. rthomas771
    The wire goes between the compressor and fan switch.
