1974 Mexican Maverick Restoration
Discussion in 'Maverick/Comet Projects' started by braess, Aug 12, 2013.
  1. braess
    braess Member
    Buchs Switzerland
    Ford Maverick GT 1974
    was working on the heater again.
    after treating the rust with some rust converter it was time to sand it down to the metal.
    now its smooth (some stains, but no more rust) and ready for paint with rust tough. that should be good to keep it rust free a few years...
  2. mojo
    I did not know any of the heater box cases had any part of the exterior case made of metal. My 73 w/ AC box is all glass on the exterior. Interesting...
  3. braess
    braess Member
    Buchs Switzerland
    its a heater case of a mexican 1970 falcon maverick, so it maybe from the falcon or it may be because its mexican. or both...
    i painted it black and it looks great and clean now! :thumbs2: :bananaman
  4. braess
    braess Member
    Buchs Switzerland
    parts, parts and some more parts...
    feeling like christmas on my birthday!!! :dance: :dance: :dance: :dance: :dance:
    received the maverick leds, thanks Carl, some seals and most important my new taillights
    lets go cutting some backpanel! :bananaman :bananaman :bananaman :bananaman
  5. braess
    braess Member
    Buchs Switzerland
    and the cluster im working on is almost finished.
    painted white, green LEDS for bakclight, wite LEDS for dummy lights and green needles to make a detail matching the car :thumbs2:
  6. tody
    tody Member
    cologne, germany
    happy birthday! you got yourself some nice presents...
  7. Rothko
    Rothko Hugo
    Mexico City
    Mexican Maverick 1973 302
    Happy Birthday Mike, nice parts.
  8. braess
    braess Member
    Buchs Switzerland
    thank you guys!
    some really nice presents... :D
  9. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Nice tail lights! I love them on the maverick I am putting together. I recommend cutting the 69 Camaro tail panel apart and welding them in versus just cutting holes in the stock tail light panel. It turns out much nicer and it does look like you just cut a hole in an existing panel.:thumbs2:
  10. 2mav4u
    Tolleson Az
    Im impressed by the quality of work! Its awesome that you have found someone that cares and takes pride in what they are doing.
    it sucks that the previous owner only covered up the bad and didn't correctly fix everything that was wrong with the car but glad that its all getting done the right way.
    Keep up the hard work and I hope it gets easier and less cost effective.
  11. braess
    braess Member
    Buchs Switzerland
    thanks for the tip, but to find a 69 camaro tail panel is in mexico absolutely impossible.
    and if i would find one, i would stop building the mav and rebouild the camaro around the tailpanel! hahah :rofl2:
    can you tell me what exactly is especial in the camaro tailpanel??
    is there something like a ring around the lights?
    i could try to rebuil this on the mav tail panel...
    thanks
  12. braess
    braess Member
    Buchs Switzerland
    thanks alot!! its good quality work they are doing, but it needs alot of effort to keep them pushing on working on what i want to get done...
    its a real shame how the previous owners worked on it, but worse that i bought it. could have bought a much cheaper and better base, but i learnt it the hard way.
    if i will look for my next project in some time, i sure will check better.
    but now im so deep into fixing mine, there is no return.
    but it doesnt get easier, and cost effective is a word i had to clear from my vocabulary.
    but thats mostly the fault of my idea of what i want to add to the car! :rofl2:
    and that is much the fault of the many great builds on here, that inspire to add more and more... :dance: :dancing: :rofl2:
  13. Cruzin Illusion
    1972 Grabber
    You can buy them at numerous places online and on ebay. They are not that expensive. You can see how I did it through my build thread.
  14. braess
    braess Member
    Buchs Switzerland
    i checked it and they are around 180USD in the states. so with transport and taxes it will be at least 300USD to have a thin line around my taillights...
    i will try bend the mav tail panel a bit, so it comes out to the cut.
    or maybe put some fine steel around it, should work as well.
    and if not i leave it flat as cid has it done in his, it looks great as well.
    but thanks for advice, ill see how to do it best.
  15. braess
    braess Member
    Buchs Switzerland
    rear bumper alignment
    they finally managed to fit on the rear bumper and check the alignment.
    they say it has to be like this, but i dont like it.
    is the original 72/73 bumper wider than the car?
    the left side gap looks not that big, but the right side i dont like.
    so probably its not well center as well.
    anyone has cut the sides of the bumper to make the lines fit better?
    where is best to cut that it looks nice and smooth?
    73_bumper_installed.jpg 74_bumper_alignment.jpg 75_bumper_alignment.jpg 77_bumper_alignment.jpg 76_bumper_alignment.jpg 78_bumper_alignment.jpg
    as well i think its a bit far away on the right side...
    any one knows how the part is called that is missing inside the bumper on the side?
    is that the lower quarter panel extension? what year i have to use that it looks better?
    and thats the bondo part which was there before, i think the car is now at least 20kg lighter as all the bondo used by the preowner is off... :rofl2:
